Question about Hardware & Accessories
I have a 12 hr timer above my thermostat. I can't turn on the air conditioner. What do I do? Its stuck on 4 hours.
And its preventing me from getting air circulation to the rest of the office. How do I prevent it from doing that?
    Top Expert:
  • Hardware & A... Master
  • 45,139 Answers
If it is stuck, in all probability it will have to be replaced.
My AC gets automatically turn it off and flashing timer bulb.
First check the following first.
1. Keep the temp between 24 to 20 degree celcious
2. Check the air filters are cleaned
3. Check the power is correct.. if there is fluctuvation use stabiliser or booster
4. Check condensor coil is cleaned.
Conclusion. Every a/c must be cleaned once in 3 months and air filters are to be cleaned by every week.
Sep 11, 2015 | Heating & Cooling
What is the meaning of all three lights blinking
That means you need to drain the tank. The manual tells you how to do that.
Jul 28, 2014 | Sharp CV-P10NC Portable Air Conditioner,...
Why will the ac unit not turn on? there is power to the outlet and unit, breaker is not triped, green light is on.
Problem can be anything from a bad switch, thermostat or compressor. If you cannot do troubleshooting, you need to obtain professional service!
May 20, 2014 | LG LT121CNR 11,500 BTU Through the WaAir...
My air conditioner will not heat
Try to talk spanish to it lol have to be more specific ac itself do not heat
Nov 26, 2013 | LG LW1512ERS 15,000 BTU Medium Window Air...
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Hi, do you know where I can get the specs of the Panasonic cw-1206fu? Thanks
11,500 Btu/h (at 115V)
10.0 energy efficiency ratio
IC thermostat control allows for precise, sensitive temperature control
12-hour delay START/STOP timer lets you select start or stop time up to 12 hours in advance
Aug 12, 2011 | Panasonic CW-1206FU Air Conditioner
When setting the timer (model 12-817) power is activated between the hour choices (2 hr, 4 hr etc) but the power goes off when the dial is turned to the actual hour selection. If left between the hour...
What timer is this?
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Sounds like a defective timer.
I have three Intermatic spring wound timers that are used every day, and never have that problem.
After all, how does the timer 'know' when it's set on the 'hour' since the dial does not have stop points at specific times?
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic FD60MH Energy Controls -...
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
Hardware & Accessories Logo
162 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
