Question about Samsung Washing Machines
The rinse cup on my Samsung front load washer does not empty. Is there anything I can do to correct the problem?
    Top Expert:
  • Samsung Master
  • 44,063 Answers
It may be clogged and has to be unclogged or defective and has to be replaced.
Water is coming up in fabric softner cup during rinse time front loader
this is normal
water should go thru the softner and into the drum when the machine rinses to introduce the softner to the drum
Dec 05, 2014 | Kenmore Elite 45986 Front Load Washer
Samsung Front Load washer stops in the rinse-spin cycle.
Many washer have two pumps in them. One circulates the water, the other is the drain pump. You may be hearing the circulating pump.
Sep 15, 2014 | Samsung WF328AAW Front Load Washer
LG front load washer leaves clothes soapy. Yes cleaned trap and drum and use correct HE detergent. What else can it be?
front load machines can be soo frustrating-try using less detergent-you might try running a sanitizing cycle with a quarter cup of dry dish washer soap-sounds like your rinse cycle isn't working do you have an option for a 2nd rinse cycle-cheers Denny
Oct 26, 2013 | Washing Machines
Load come off smelly
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle or vinegar. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the unit
Jan 30, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Kenmore front Loader washer leaking from bottom
I want you to run an empty load, pour 3-4 cups of white vinager into the soap dispencer, this will flush out detergent buildup, it sounds like the unit has a buildup of soap and is oversudsing, the vinager wash will stop it from happening, if this stops the problem cut the amount of soap you are using in 1/2. If it does not let me know, good luck
Jun 07, 2010 | Kenmore 43142 Front Load Washer
Rotten Egg Odor from washer
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
NOTE(Follow the procedure correctly as stated. If the issues persist, this may lead to a deceased rodent, or small mice that has crawled into the unit to die. This is highly uncommon, but possible)
Nov 02, 2009 | Whirlpool GHW9100L Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
LG washing machine problem
I had the same problem with my LG front load. The second repairman fixed the problem. The water lines going into the machine were clogged with sediment (probably because I have well water). This caused the cups to remain full of water because the water pressure was so low the siphons were not working as they should to empty the cups. This also caused the wash cycles to be extremely long (sometimes 2 hours) because it took so long for the water to enter the machine for the wash & rinse cycles. Since the lines have been cleaned it works fine.
Jan 08, 2008 | Washing Machines
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
