Question about Garmin Nuvi 680 GPS Receiver
The screen has become unresponsive on my GPS type NUVI 680 NA. What to do ?
  • Garmin Master
  • 2,130 Answers
Touchscreen must be replaced. See here for more info.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Posted on Aug 11, 2017
SOURCE: unlock nuvi 680 na please
I think you have to send it back to Garmin. Liam
Posted on Jun 18, 2009
  • 109 Answers
SOURCE: i need to update my map for my nuvi 680 na. where
nuvi.com
Posted on Aug 15, 2009
  • 13433 Answers
SOURCE: touchscreen on garmin nuvi 680 GPS stopped working
Try reseting the nuvi, there is a reset button on the bottom or on the back, some models have it on the front under the display cover.
if that doesn't help the digitizer which is the part on top of the lcd display that registers the touch could have failed and may need to be replaced.
I haven't seen many garmin repairers, you might have to get in touch with garmin about it, check ebay for replacement parts but if I remember correctly garmin takes care of it and don't distripute much parts.
Posted on Sep 10, 2009
  • 638 Answers
SOURCE: can't unlock my garmin nuvi 680
There is NO master reset code. Whoever told you this was wrong. You have to use your security location to unlock it. Otherwise, you have to send it in to Garmin with the original receipt from an authorized Garmin dealer. This is to prevent use of the unit in case of theft.
Posted on Mar 04, 2010
sharcnet
  • 2130 Answers
SOURCE: I have a Garmin GPS nuvi 660 NA. The unit will
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jun 21, 2010
Garmin 680 nuvi screen unresponsive worked fine then not. no temp or hit prob
I will suggest you reset your GPS, to reset your gps, follow this steps, turn off your device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press Yes to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 to 30 minutes in order for it to requires fix to GPS satellites. with this, the problem should be rectify.
Nov 27, 2010 | Garmin Nuvi 680 GPS Receiver
I am looking for a repair manual.. Does anyone have one in digital format?? 2.5 yo Nuvi 680 na touch screen stoped working. matbe a bad connecton.. I cant get it open there are only 2 screws I can see...
If the Touch Screen isnt working, have you tried to recalibrate the screen?
Turn off the Nuvi and then back on.
Slide Power key to the right (lock )
Hold your finger on the screen for about 30 seconds untilthe calibration screen appears.
Follow the on-screen instructions...
Also the 2 screws you took off once you done that you would have to use a plastic pry tool to lift cover up
Oct 26, 2010 | Garmin Nuvi 680 GPS Receiver
Touch screen not responsive Garmin 680
The cable to the touch sensitive part of the screen may have come loose (easily happens if knocked).
Try taking the unit apart (with care and the right type of screwdriver) and reseating the connector cable.
Once you've done this you may need to recalibrate the screen. Holding the power switch down will get you to the reboot / recalibrate screen.
But of course this will probably invalidate your warranty so beware.
Nov 04, 2009 | Garmin Nuvi 680 GPS Receiver
Touch screen not responsive. LCD screen OK.
Try to calibrate the touch screen .
If not send it to a repair centre they will fix the touch screen for you.
Try here www.satnavrepairservice.com
Regards
Jul 18, 2009 | Garmin Nuvi 680 GPS Receiver
Unlock nuvi 680 na please
Jun 17, 2009 | Garmin Nuvi 680 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 680 GPS Receiver Logo
57 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
