My machine has an auto dispenser for bleach and softener. Water will not run into the dispenser. Why
zeusfaber
  • 247 Answers
SOURCE: Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
Posted on Jul 16, 2007
  • 641 Answers
SOURCE: automatic fabric softener dispensor not emptying
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle)by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Aug 06, 2007
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
SOURCE: Bleach and Fabric Softener Dispensers don't work
I've fixed part of this problem - I have a GE GBVH6260. I took the top cover off: first, take the three screws out behind the control panel at the front, then take the long skinny trim piece off, then take three screws out of the very back of the machine at the top. The top cover will now slide back and come off. There is a handy technician's manual taped to the frame under the lid. In the manual, there are instructions on how to test all the functions of the washer. Turns out the motor that moves the water spray from soap to bleach to fabric softener works just fine on my machine. The water spray just isn't very forceful, so we've watered down the fabric softener and maybe now it will flush out properly.
Posted on Apr 07, 2008
SOURCE: MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Posted on Dec 08, 2009
We use well water . after washing tower 2 or 3 days of use tower it starts to smell musty .how do we prevent this?
If the machine has a "clean washer" setting, run that with 2/3 cup bleach only (no soap). If it doesn't have a specific setting to clean the machine, run a small load with hot water and use 2/3 cup bleach, no soap.
If you're asking how to avoid the problem altogether, you'd most likely need to install a water softener, or water filter.
Mar 17, 2015 | Kenmore Elite 45986 Front Load Washer
Bleach dispenser
Check water flow INTO the dispenser. This happens during the
cycle to dispense the bleach evenly through the load.
Jul 22, 2014 | Frigidaire Washing Machines
Kenmore frontloader fabric softener dispenser is clogged
There should be pins located somewhere on the dispenser or a grey thing located inside the dispenser, push it down and that will release the dispenser from the washer. Afterwards you can put in in the dishwasher, this should clean out any clogging residue.
Mar 10, 2013 | Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Water stays in softener and bleach dispenser after washing
water stays in the softener and bleach dispenser after washing and also the bleach is not dispensing
Apr 26, 2010 | LG WM-2277HW Front Load Washer
Water left in fabrish softener dispenser after wash cycle
My Frigidaire front loader was doing the same thing and also not taking the bleach. I could hear that the water pressure was not real strong when I turned the machine on. I removed the two small screens on the back of the machine where the water supply hoses attached, found they were partially clogged and cleaned them well. The bleach and softener dispensers are now working like new.
Aug 03, 2009 | Bosch Washing Machines
Bleach dispenser Kenmore Elite HE4t Model 45986400
is the machine level or is something plugged anywhere?
Mar 27, 2008 | Washing Machines
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
