Question about Frigidaire Dishwashers
I have a Frigidaire model dishwasher, wich makes banging sounds between cycles. Can you give me some idea what to look for, and check?????
Model no. is FDB510LCB0/ Make Frigidaire
    Problem Solver:
  • 17 Answers
Don't let dishes hit the turning arms
Posted on Jan 03, 2017
    Top Expert:
  • Frigidaire Master
  • 35,531 Answers
Could be loaded incorrectly
Testimonial: "No this banging happens everytime I run the dishwasher, usually between every cycle, sometimes loud, sometimes I think its going to explode lol"
  • Patrick Wilhelm
    Patrick Wilhelm Jan 03, 2017
    the banging sound happens evertime I run the dishwasher sounds like something not shifting properly during cycles. does this even with a empty load. HELP
  • Patrick Wilhelm
    makes a rough banging sound
Beeping sound dishwasher
Might try to find the solution to your problem but it will help if you provide the model number of the Frigidaire dishwasher. Mostly these can be done by pressing a combination of keys on the panel.
Feb 15, 2014 | Frigidaire Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Standing water in model FDB1050RESO frigidaire electrolux dishwasher 2005 model
Good Afternoon Friend,
I see that you have standing water in your Frigidaire dishwasher, model# FDB105RES. I would suggest trying the troubleshooting tips below:
• If your appliance is hooked up to a food waste disposer, make sure the disposer is empty.
• Check to see if the knockout plug has been removed from inside the food waste disposer inlet.
• Check to see if the drain hose is kinked.
• Make sure the cycle is complete and not in a pause mode.
If you are still having trouble with your dishwasher not draining, I recommend contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    My frigidaire dishwasher model # FDB4315LFCO, is ending the wash cycle with the dishes dripping wet, what might be the problem?
    Check your heating element..
    A bad heating element causes many problems in dishwashers...
    Dishwasher Problems The Heating Element not Working
    How to Replace the Dishwasher Heating Element
    Dishwasher Maintenance
    heatman101
    Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
    Aug 14, 2011 | Frigidaire Dishwashers
    I had a glass break in my Frigidaire dishwasher and now after it has completed the cycle there is still water in the bottom of the washer.
    Please provide the model number of the dishwasher so that I can give you some idea where the broken pieces might be stuck.
    Mar 10, 2011 | Dishwashers
    My Frigidaire dryer makes a banging noise
    What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
    Jun 09, 2009 | Frigidaire GLER642A Electric Dryer
    Frigidaire Dishwasher Energy Star blinking lights.
    Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
    Go figure.
    Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
    LG 3 in 1 Dishwasher model LD2131SH
    E1=Water inlet Error
    Not reached to the normal
    water level in spite
    of 10 min. water supply
    Causes:
    The Water Supply Tap is closed.
    The Water Supply is shut off.
    The Inlet Hose is kinked.
    The Water Pressure is very low.
    (below 10 psi)
    Inlet Valve is OK?
    The filter of Inlet Valve is clogged
    by impure water.
    The Hall sensor is OK?
    The Impeller of Air Guide is bound
    Solutions:
    Take action on Water Supply
    device.
    Measure the electric resistance of
    Inlet Valve. (950-1300 )
    Clean the filter of Inlet Valve.
    Check the frequency of Inlet Water
    by the Test Mode.
    Replace the Air Braker.
    Aug 14, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
    Dishwashers Logo
    47 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
