Question about Kenmore Washing Machines
Hi is it pretty simple to replace parts like BELTS. or. AXELS pulleys on a Kenmore stacked washer/dryer? and are there any TUTORIALS TOU CPULD RECCOMEND FoR DIY need fix dryer belt axel possible
  • Kenmore Master
  • 5,323 Answers
YOU CAN FIND EASY HELP ON GOOGLE OR YOUTUBE , JUST WRITE FIX CHANGE BELT ON STACKABLE DRYER ETC
USUALLY U HAVE TO REMOVE THE TOP PANEL THEN THE BACK PANEL
SOURCE: Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Posted on Dec 26, 2007
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
  • 5 Answers
SOURCE: stacking kenmores
Yes. When I bought my washer and dryer, it came with the stacking kit.
Posted on Nov 24, 2008
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
SOURCE: REPLACE BELT
Hi there ,
how do I get the belt around the drum ? do I have to take the whole back panel off the dryer ?
Don
Posted on Jan 16, 2010
Dryer belt diagram how it goes on pulleys
usually 2 small pulleys one on tension-er spring push it in or you can not get belt on
belt makes an S on small pulleys one of the pulleys is the motor most belts are grooved flat side to dryer drum grooved to motor pulley flat to tensioner pulley do not flip belt
Jun 09, 2011 | Kenmore 98702 Stacked Washer/Dryer
Problem is the belt around the drum is sqeaking and the pulley appears to be causing the noise. The drum stops turning as the belt starts to move from its original position. How do i get the pulley and the...
Sounds like you need to replace the pulleys and the belt...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
Apr 15, 2010 | Kenmore 94702 Front Load Stacked Washer /...
We have a stackable kenmore washer and dryer. The belt started to slip and smoke on a heavy wash load. I replace the belt but it still smokes and wont spin. Is there and adjustment?
Hi, There are no adjustments. Make sure the pulley on the idler and the drive pulley are tirning freely. It is possible the transmission is locked up and the belt will not turn properly.
If all the pulleys are free, start the washer in the spin cycle while watching the drive pulley to see if it turns.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Squealing dryer
Most dryers have a vented access panel on the back on the bottom that is held in place by a couple of screws so you can get to the motor & pully assy. Check to see if the grease has dried up on either the iddler pulley or drive pulley. If needed, push down on the iddler to release pressure on the belt and give the pulleys a spin. If they seem fine then it will be the belt or possibly an overloading problem.
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Maytag stacked washer/dryer fills with water, makes noise like it's working, but won't agitate, but at the end of it's cycle pumps out but won't spin either. Is this a belt problem? If so how hard is it to...
Definately sounds like the belt is off. Not too big of a problem for small hands mechanics. Usual problem lately with Maytag is the spindle pulley. For some reason they haven't been tightened properly and the pulley and belts are falling off. Pull it out from the wall remove the panel and see what you've got, really simple on the bottom end. Complicated stuff is up in the control panel. Make sure you get the pulleys lined up as close to level as you can or the belt will jump off on you during spin cycles. Good Luck!
May 10, 2009 | Maytag LSE7806A Top Load Stacked...
Rattling
Level the drier, check the drum for foreing objects, check your belt and replace if need to. Check your rear drum seal, and your drier idler pulley, and replace if need to.
Jul 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
Belt Keeps Breaking
Maybe it cause a too tied belt.
Oct 03, 2006 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
