I have a seeburg V-200 that won't scan after playing a record,it just sits with the turntable turning.It will not manually scan either.
SOURCE: turntable plays too fast
I have seen this problem before. Lift the turntable off. It might be held down with a clip around the center pole. Under it you will see a wheel that contacts the turn table and the center shaft of the motor. The motor shaft has 3 0r 4 elevations with different diameters. When you change the speed the wheel will move up and down to different diameter levels on the motor shaft. It must be free to move. It might need some oil at the moving parts as I suspect it is not moving properly.
Hope this helps.
Posted on May 08, 2008
SOURCE: Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Posted on Apr 10, 2009
MechMusicSF
  • 16 Answers
SOURCE: Mechanism will not pick up records
You have a read out, or a write in problem.
Either the selections are not being written to the memory, or they are not being read by the scanning mechanism.
You'll have to determine which situation you have, which can be difficult for a novice. "Seeburg won't pick up" is the most common problem because it's either a "write in" or "read out" issue. Various tests are too complicated to explain via this forum.
Might be time to bring in a professional.
Also, be sure if you have service done, the guy gives the machine a good lubrication.
Kyle~
Posted on Apr 18, 2009
  • 38 Answers
SOURCE: juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
Posted on Jul 08, 2009
MechMusicSF
  • 16 Answers
SOURCE: seeburg selectomatic 200 [has been stored in
1. Check to see that the end of record switch is OK or not shorted, same with the reject button on the back and all associated connections.
2. THESE THINGS NEED OIL! The trip lever (just to the right of the tonearm) may not be resetting fast enough, or at all, due to gummy grease. Buy the manual (eBay - any service man will insist that you have it.). It will show you where to lubricate everything. NO 3-in-1 or paraffin based oils.
Posted on Feb 28, 2010
Seeburg 1960 AQ 160 Jukebox. The mechanism very hard to turn even with finger. Turntable not turning with lube added.
Rotate by hand till shaft actually receives lubricant especially if you did not remove the turntable to apply the lube 1960 model all oil dried up contaminated with dust of 57 years
Apr 25, 2017 | The Audio Players & Recorders
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
Seeburg jukebox ay160 won't select record
(1) Make sure that the credit unit is not stuck and that all of the contacts open and close correctly while manually operating the solenoids. Lubricate it if the wheel does not turn freely. (2) Make sure that there are credits on the machine. (3) If it still wont select check fuses or (4) try pressing the letter and the number simultaneously, some "free play" set ups will work this way.
Jun 09, 2012 | Audio Players & Recorders
I have a 1971 SEEBURG MODEL USC2 "Bandshell"
Tormat has been energized by movement over the carpet, someone touching it with a high charge or natural static in the air of a dry house. There is a procedure to deenergize the tormat with a battery. I am searching for the battery size and procedure myself. I will come back if I find out
Jan 11, 2011 | Audio Players & Recorders
I have a LPC 480 Seeburg Jukebox that scans, pick up the record, the needle touches the record, then returns the record to the carriage without playing. What can I do?
Try reading this, basically the fault can be in the mech, the amp or trip switches.
http://www.flippers.com/Seeburg-trblshoot.html
Nov 28, 2010 | Audio Players & Recorders
I have a buzzing when the record is about to play and during playing on a Seeburg v 200
a buzzing is usally a bad earth,you will find an earth lead,which runs along with the phono plugs which connect to the source you have it,the earth needs to be fixed also.
or you may have a loose connection on your cartridge,which houses the needle
Dec 25, 2009 | Audio Players & Recorders
I have a Seeburg MCU3 Prelude - had is repaired a couple of months ago...it worked fine...I have not played in in about a month and the part that actually plays the records won't turn or move from side to...
No, but like any machine, it does need lubrication once in a while. You should purchase a manual for it (eBay).
If the clutch has become stuck, it's time to call in a pro.
Are you sure it's in "PLAY" mode? Check to be sure the service switch is in "PLAY."
Does the motor turn?
If yes, try pressing the reject button on the back. Maybe it's stuck thinking it's playing a record in an empty slot (clamp arm will be against the turntable). There is also a manual trip lever just to the right of the tonearm. lift up on it if the motor is turning and see if that triggers it. Go ahead, it won't hurt you.
if the motor itself has frozen up from lack of oil, try putting some light machine oil (NOT 3-in-1 or anything paraffin based) in the oil cups on the side of the motor and letting it sit for a few hours. Then, turn the motor shaft by hand a little. This may free it up. if so, count your blessings and call someone in to give the whole mechanism a proper lubrication or something else will eventually seize up or wear out.
Good luck.
Dec 24, 2009 | Nostalgia Electrics Classic Music Jukebox...
Seeburg selectomatic 200 [has been stored in garage for 30 years ] all funtions work properly except it will only play record for about 1 second, then eject & go to next selected record & play for...
Oct 24, 2009 | Audio Players & Recorders
Juke box (seeburg 480 serieswill take coins but won't play record
PROBLEM.
DOCTOR FIX
6362273300
May 09, 2009 | Audio Players & Recorders
 Grubhead
Grubhead
