Question about Vizio Televison & Video
I have a vizio tv that has a faulty t-con board: CPWBXRUNTK5261TP (ZC) I ordered a new t-con board but it ends in (ZH) instead of (ZC). Will the (ZH) work fine, it looks identical to my (ZC) board?
  • Anonymous Jan 03, 2017
    I spoke to the manufacturer and confirmed that the (ZH) is compatible with the (ZC)
    Sergeant:
  • 246 Answers
No not the same.return and get the correct one. do not dry the board
Posted on Jan 03, 2017
sandie3796
  • 132 Answers
SOURCE: when I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Posted on Mar 03, 2010
eagle338
  • 4889 Answers
SOURCE: I have no power on my Vizio 22 plasma tv. I
Vo22L is an LCD tv not a plasma. When you say no power, What is the status of the LED at the front?
Posted on Jan 19, 2011
  • 8457 Answers
SOURCE: have recently purchased new tv/dvd.
Tv is new bring it back where u bought it and exchange it for another tv,this tv have problems,with it bubble laser eye data reader,could be bad,that why it not detecting the DVD disc shinning data's surface.
Posted on Mar 21, 2011
bugoy31
  • 1238 Answers
SOURCE: vizio m420nv has sound but no picture
Hello there
Actually that problem is very common on all LCD TV,, that problem is cause of either inverter board or t-con..
In this case you don't need to check the voltage that is too complicated for you,,only visual check is enough..
I share you my tricks and hope it helps..
Power on your TV turn off your lights..if you will see the light comes from the screen the problem is t-con..if no light the problem is inverter board (backlight) board
Hope it helps..
Don't forget to rate..
Posted on Aug 25, 2012
Slinteriors
  • 8617 Answers
SOURCE: bad T-con board on my vizio tv
You can easially do it yourself only takes a couple of minutes to replace the TCON you can get replacement TCONs from www.tvrepairworld.com
Posted on Oct 23, 2012
I have a Vizio E320I-A0 and it has multiple vertical and horizontal lines on the screen, how do i fix that?
Probably the T con board is faulty. T con board is the one which drives the lcd pixels. Chekc the video to identify the t con board. Also try to remove the connection to T con board and reconnect it. some times bad contact on those connectors can lead to such problems.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
Sep 22, 2015 | Vizio E320i-A0 32 Class LED Smart TV
What can I do? I have a Vizio Smart TV 32 in model # E322AR. When I turn it on it shows 2 screens in black and white. When I hit the menu button it shows it in 4 rows going down and 3 rows across. And
your problem is most likely due to a faulty t-con or main board. The good news is that research shows that your t-con and main board are all in one. Vizio's are known for bad main boards. The question is it worth repairing? The good board from a reputable company will cost $80 plus, the prices on 32" sets are below $200 in some markets nowadays. If I have been helpful please sign my guestbook!
http://www.back2lifeelectronics.com/Guestbook.php
Jun 10, 2014 | Vizio E322ar - 32 Class 31.5 Viewable Lcd...
T-con board
The T'Con board will have a number printed on it. It should be noted, before ordering a new one. To buy it on line, check this link. www.alibaba.com. If you wish to get more details, check the site linked here. Pull up older posts.
Dec 01, 2013 | Vizio 55" M550NV Razor LED LCD HDTV, 1080p
Vizio E371VL screen won't come on
most certainly bad capacitors in the power supply unit,inside the tv.look for buldged capacitors and replace with same kind.cheap fix if you can do it.requires removing the faulty cap and replacing with new one.most cost very cheap
Mar 12, 2013 | Vizio L32 32 in. LCD HDTV
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
Blue line going vertical on my vizio VX42L
Check all the connection sockets from T'Con board to LCD panel for any loose. Re-seat them. If this do not help you, T'Con board is faulty, and should be replaced.
Aug 17, 2012 | Vizio VX42L 42 in. LCD TV
I have a Vizio VF550XVT1A. First problem was a flickering screen that ended with the TV turning off. I replaced both invertor boards and the TV seemed to work fine for a few weeks. Now the TV works fine...
Good day sir Alfred!!!!
If your screen turns to back after a minutes but the sounds is normal..That problem is very common to all flat panel specially to LCD TV..
OK,I need to know first if your TV having a back-light when the picture went out after a minutes.If that so the possible problem is T-CON board (this board is the responsible to produce a video on all LCD TV)..
If you don't have back-light the problem is inverter board again..But before you order or install new inverter board try to find why the inverter board gone only on few weeks after you install it..the possible problem why the inverter board faulty for the short period of time is higher/lower input voltages (24vdc) comes from power supply..try to check it using volt meter or multimeter tester..it should be read 24vdc on meter..let me know if the voltage drop or higher to 24..
If the 24vdc is fine the only problem is the condition of inverter board maybe its used or partially faulty when you buy it..
if you have more queries and clarification regarding my solution please feel free to reply on this tread...
Hope it helps..
Thanks for using fixya..
Feb 18, 2012 | Vizio Televison & Video
I have a 47" Vizio
This problems the tv serveral vertical lines show up on the LCD screen panel by itself?Yes,the tv board that call the T-CON decodering board is dying.The T-CON decodering board it sit at the middle bottom of the LCD screen panel.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.If these vertical lines cause by an object or a person by hitting the LCD screen panel,tv is not repairable,because the LCD screen panel is dead not worth replacing because the LCD screen panel are 90% important to the tv and cost the same as a new tv.
Mar 26, 2011 | Vizio VO47L 47 in. LCD TV
My vizio has to warm up before the screen turns to its regular blue no signal screen, and then when it does there are vertical lines all across the screen. Any solutions?
Hi:
This problem may be due to a faulty T-Con board, but first check the power supply for faulty Capacitors, there may be swollen of puffy tops on a couple of capacitors usually located near the connector plug going from the PS to the Main board. If all capacitors look fine then replace the T-Con board.
Dec 19, 2010 | Vizio VO47L 47 in. LCD TV
Televison & Video Logo
49 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
