Question about Whirlpool Washing Machines
How do i program my sicle on my whirlpool CGT8000XQ washing machine
2 Suggested Answers
  • 653 Answers
SOURCE: MY KELVINATOR KL15TL WASHING MACHINE DOES NOT
I can think of three possible causes. The first is the timer not advancing to the wash cycle. Try manually advancing the timer and see if it will start. The second possibility is the drive motor or drive belt. Open the access panel to see if the belt is intact, then see if the motor starts when you manually advance the timer to wash. The third possibility is the lid switch. You can usually get to it by inserting a putty knife in the two from corners to pop the spring clips open, and the top flips back.
Posted on Aug 20, 2009
Is not taken the softner and the bleach
Clean the dispenser with boiling water and see if it is just a sticking problem, these get gummed up after a while.
Aug 19, 2016 | Bosch Nexxt 300 Series WFMC2201UC
How can i fix machines from saying "out of order" when they shouldn't be ?
you may need a seperate wire from the switch board to power the other washing machine. The wiring to the washing machines are most likely on the same wires from the circuit board. These wires would have a maximum current drawn figure of most likely 15 amps. If you plug two washing machines in then the current being dragged out could be 15 A on one washing machine and the other washng machine would be in Parallel with this washing machine that is running. The total resistance loading would be altered and lowered thus pulling more current. However the wiring may have a maximum current load and maybe the other washing machine is detecting a voltage drop due to the other washing machne taking the load of current and voltage. An electrician could check this train of thought / theory out .
Oct 20, 2015 | Washing Machines
My washer dos not drain complitly, in the last sicle, wath doyou tink worn out pump?
no, i do not think it is worn, but there is a possibility that it may have a lot of debri inside of it...
also check to make sure your hose is not kinked
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
The machine keeps indicating a closed water tap! very little water entering the drum.
chek ur whater temp on ur sicle and then if dont work just turn the taps fuul power
Nov 19, 2009 | Whirlpool LHW0050PQ Front Load Washer
MY KELVINATOR KL15TL WASHING MACHINE DOES NOT START THE SICLE AFTER LETTING IN THE WATER
Aug 20, 2009 | Washing Machines
Will not pump out all water.i have replaced with new pump
timer is not giving the spining sicle complet check the timer
Aug 12, 2009 | Roper RAS8445KQ Top Load Washer
Water leak on sping sicle /model 24632300
POSSIBLE BAD WORN PUMP EASY JOB TILT BACK AND SEE 2 CLIPS HOLD PUMP TO MOTOR SHAFT
Apr 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
CLOTHES COME OUT REALY HEVY AND WET AFTER WASH?
It sounds like the spin dryer is not working properly.
Oct 24, 2008 | Washing Machines
Whirlpool -ghw9100lw1 wont start sicle
defective timmer, defective water level pressure switch open circuit
Oct 08, 2008 | Washing Machines
Washer wont start
see this link to test it for issue
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Jan 13, 2008 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
