Question about Radio Communications
Hot roding Bluetooth headset - Radio Communications
How do I pair my Bluetooth blue action BT-EVE033
BlueAction Brushed Aluminum Bluetooth Earpieces (Hot Pink)
www.tesonicusa.com > Bluethooth
Please wait... Gift Certificates · My Account ... BlueAction Brushed AluminumBluetooth Earpieces (Hot Pink). Image 1 ... Item Code: BT-EVE033-HPK. Color: Hot ...
BlueAction Brushed Aluminum Bluetooth Earpieces (Silver ...
It is 100% universal and can be use with all Bluetooth appliances. Auto paring function ... Gift Certificates · My Account. Whole Sale Sign ... BlueAction Brushed AluminumBluetooth Earpieces (Silver). Image 1 ... Item Code: BT-EVE033-SIL ... Multipoint techonology, pairing with TWO Bluetooth devices simultaneously. - Sleek ...
Jan 07, 2016 | Radio Communications
I have a M100, and it quit working. thought it needed charging but when plugged up no lights and unit gets extreamly hot
It is not safe to use the unit if it is getting hot while charging. The batteries are non replaceable for this headset. If it is under warranty you should have it replaced. If it is no longer under warranty, you will need to purchase a new headset.
Here is a link to the User's Guide.
Good luck from Headsets Direct!
Jul 10, 2011 | Plantronics M100 Bluetooth Headset
Hot to connect samsung wep300 bluetooth device to laptop
Firstly download PC Suite and install it on your PC then please follow these steps..
1.open to PC Suite and make sure Bluetooth must be open of both Mobile and PC
2. Select setting >Add more Phone
when detecting process will be complete then click on mobile then select next
after that follow all steps and you can connect your pc via Bluetooth with mobile...TRY IT..
Jul 10, 2011 | Samsung WEP 300 Bluetooth Headset
Just bought the samsung hm 1100 bluetooth headset and i tried plugging it in to charge it and no light comes on at all it has just got really hot any ideas why its not working ?
If it gets really hot this indicates a short in the charging circuits or battery, this is clearly a manufacture defect and should be returned for exchange.
Jun 22, 2011 | Samsung HM1100 Bluetooth Headset
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
I have hot the new ps3 and i have live and a
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Jan 24, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I broke the ear clip, where do I get a new one?
If you go to your Cellular providers retail location, you can get parts at their service desk. Hope this helps
Jun 26, 2009 | Blueant Blue Ant 093732 X3 Micro Bluetooth...
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Radio Communications Logo
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
