Question about Amana Washing Machines
Amana Nfw7200tw door lock won't release - Amana Washing Machines
  • 92 Answers
SOURCE: the door is open, but the latch is in a locked position.
it sounds like the child lock as been turned on,check the handle part to see if it as a **** in it were you can turn it with a screwdriver just turn this upwards or sidewards to see if the door will lock or open ?.rgrds,paul
Posted on Jul 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Amana washer NFW7200TW reversable door
It's not as simple as switching the door - you must get a kit - with different hinges.
Instructions are included with the kit..
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Posted on Dec 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have an AMANA waser,
Go ahead and remove the bottom panel. Your tech sheet is there. Remove the pump filter and check for objects blocking the pump. Have rags and stuff at the ready. Unplug the machine or kill the power to it and the dryer. The Handy Hippy has a nice video which shows you how HERE
Posted on Dec 13, 2010
Amana nfw7200tw will not run. all wash settings read 1 extra minute. Is this a code or something like that?
have you tried unplugging and resetting the computer, it seams hung in the last cycle, can you open the door and remove all inside, reset it again and try it, the washer sounds like it has water in it and needs to drain first,if it is full of water you have to drain it, by moving it and taken the drain hose off the pump,if that's the case i recommend flushing the inside with hot water and some bleach right through the front door or reservoir on top,after you get it emptied, the water sensor may be full of soap, by the way the soap your putting in this machine should only be about a 6th of a cup, I know it sound crazy but a half or a 3rd is to much, for the sensors, try this an get back to me,Matt
May 01, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
Error code: d5 . What is wrong?
The error is dS meaning there is a problem with the door switch. Here is the switch to order.
The video above will show you how to replace the switch/lock.
Sep 26, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Door latch stays locked
remove the top and there is a manual release for the door near the latch. You will need to replace the door lock. Here is a link to the part.
Oct 17, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
The door is open, but the latch is in a locked position.
Jul 07, 2009 | Washing Machines
Amana front load washer door locked with door open
Feb 25, 2009 | Amana Washing Machines
Washing Machines Logo
37 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
