I have a Stapes Paper shredder SPL-1506X that runs but wont grind. The optics appear to send the unit into reverse as soon as paper in inserted, also runs continuously.
5 Suggested Answers
SOURCE: Ativa SPL 1506X not working
I had the same "click" noise when trying to shred. I had a Staples replacement guarantee (extended warranty) so I called them up and described the issue. They are sending me a gift card for the purchase amount. Seeing as they did not want the original unit back I decided to take it apart to see if I could find the problem. I did not find an issue with the gear as the other user stated but I did notice a burn mark on the circuit board just under the relay (which could make a click noise) I removed and inspected the relay (desoldered), but I could not see anything wrong with it so I re-soldered it back onto the board and re-soldered (re-flowed) all of the other connections just in case there was a cracked joint. Upon testing the shredder still has the same "click" sound. My guess is there is a faulty device on the circuit board such as a resistor or relay. To sum it up, to repair this particular issue you will be unable to implement a "simple" fix and it would realistically require either a new circuit board or a whole new shredder.
Posted on Jun 22, 2008
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
  • 35 Answers
The optics are OK!
There is a small electromagnetic sensor on the cuttershaft which senses the input load.
I could be maladjusted or defective.
Posted on Feb 23, 2009
SOURCE: Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
Posted on Jul 04, 2010
Why does my shredder run when there is no paper, but stops as soon as I insert paper into the slot?!
You may have paper stuck in the blades and its jamming.try forward and reverse to free it up or you may have the head unit on the can faced the wrong way. Pull it out and turn head around and than try. I know on some shredders if the head unit does not fit on the right way it wount push down the safety switch and it wount run.
Mar 02, 2015 | Omnitech 10-Sheet Micro-Cut Shredder
How to oil shredder staples spl-1506x?
You can buy commercial products, or run some wax paper through your machine periodically. The wax will not gum up like oil and attract dirt.
Jul 13, 2014 | Staples Office Equipment & Supplies
Spl-1506x shredder only runs in reverse
Unplug the shredder... Take the top off and turn it upside down. Use a screwdriver to take the lower cowling off and look at the motor. If the mounting area where the motor sits looks melted at all, the machine is toast. If the motor mounting area looks good, look at the slot where the paper is inserted... there should be a sensor (that "sees" the paper when you insert it) at the paper slot. Check to see that the sensor isn't damaged.
Nov 11, 2012 | Staples SPL1506X (CrossCut) Shredder
Automatic switch does not shut off after shredding on Staples model SPL-1506X shredder.
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Feb 13, 2011 | Staples SPL1506X (CrossCut) Shredder
The blades are stuck in reverse
I have the exact same problem. In fact, my SPL-1506X is sitting disassembled on the kitchen table as I write this. There is a PC Board inside the unit with a relay that directs the motor to run in forward or reverse. My relay is fused in the reverse position. I know this because the relay's casing is clear polycarbonate. If that relay can be replaced, the SPL-1506X will be fixed, I'm convinced. Unfortunately, the relay is made in China. So much for quality! I located the part no. on the web: Sanyou SME-2110DP a DPDT relay. If you can find it(which I can't), you're in luck. Myself, I'm going to trash the unit.
Jan 14, 2009 | Office Depot Ativa DQ60M Shredder
SPL 1506X Shredder
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
SPL-1506x issues
Chances are a gear has broken. This problem requires labor and parts which in some cases is as much or more than the original equipment.
May 18, 2008 | Office Depot Ativa DQ60M Shredder
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
Shredder problem
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Feb 23, 2008 | Fellowes DM15C Shredder
27 people viewed this question
