Question about Vacuums
My proheatessential not spraying when set on floor cleaning
Button seems ok, water comes out of tank ok, hand held works
5 Suggested Answers
SOURCE: Bissell 1698 Powersteamer no spray
If it seems like the tank does not fit in securely, the round gasket that goes around the valve at the bottom of the tank may have come off and actually be in the hole in the bottom of the vacuum base. It looks like it belongs there but you can pull it out with some needle nosed pliers. After you remove it, put it around the valve on the bottom of the tank, then it will fit into the hole again and everything should seal correctly. Mine was not spraying and would not suction well. figured this out and now it works great again.
Posted on Sep 05, 2007
SOURCE: Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Posted on Nov 05, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
heatman101
  • 43501 Answers
SOURCE: have water at the hand held but none out the bottom
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhklui
Posted on Sep 30, 2010
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
I have a bissell pro heat 2 it will spray water through hand held pipe system but wouldnt spray from main capet brush area can you help me please
Ours would not spray water either, after messing with it for ages I discovered the round black housing that the tank locks into where the water flows out of the tank was loose. So I held the housing from underneath while seating the tank & it started working. It's very flaky & a lousy design. Good luck.
Jan 16, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
When button is pressed, water does not come out of the holding canister. still seems to have suction, but water doesn't come out to rinse/clean carpet.
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 22, 2010 | Bissell 9200 Upright Vacuum
My Bissell Proheat Clearview is not spraying water nor taking
heatman101
wrthrw
Apr 25, 2010 | Bissell 1699 ProHeat Clear View Upright...
Doesnt pick up water
Possible Causes Remedies
ReadyTools Dial may be at the wrong setting for the cleaning job <> Set ReadyTools <> Dial to either Tools / PreTreat or Floor Cleaning.
Nozzle Window may not be properly attached. <> Press down firmly on the black oval gasket at the top
Window to make sure the two tabs on the back of the Nozzle Window are snapped into the mating slots in the main housing.
Tank-in-Tank lid is not installed <> Re-install lid;
Tank lint filter is blocked <> remove all lint and debris from Tank lint screen.
Tank-in-Tank is not properly seated. <> Tank-In-Tank must be firmly seated to function; remove
and reseat Tank-in-Tank.
Poor tool position (Hand held attachments only). <> Adjust angle; apply more downward pressure.
Tank-in-Tank has picked up maximum dirty water <> Empty Tank-in-Tank
Front Clear Floor Nozzle Window ids blocked <> Remove window and clean all fibres and debris then replace.
Insufficient suction <> Clean Pre and Post Motor Filters.
Sep 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Clear won't spray from floor nozzels but it does stray from hand cleaner
Usually when the hand tool works ok, then the heater inside the handle asm. is clogged. The water bypasses the heater when you use the hand tool. Other then that it could be a bad pump.
Apr 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
