Question about Cell Phones
My Sony W350 give an error for third party downloads. After installation it won't open. Their is a picture of a little key and file. Looks like phone is locked for third party applications. Is there a way to solve this? Thanks
On my Huawei MyTouch Q phone the com dot huawei dot mytouchlauncher app keeps stopping unexpectedly whenever installing new apps
Resolution Steps App previously worked
If the app that is showing errors has previously worked and not been updated, follow these steps:
  1. Think about the pattern of what you were doing when the device froze, and what programs were open in the background. Use the answers to focus on device functions or apps that are not working correctly.
    Note: If the problem is related to more than one specific app, see: Device is slow / freezes / restarts / or displays memory errors: Android
  2. Check the docs for your device to see if there are any specific instructions for it
  3. If the problem is related to contacts or an 'android.process.acore', back up your contacts:
    1. From the Home screen, press the Menu key.
    2. Touch Settings.
    3. Touch Accounts & sync.
    4. Turn off all synchronization to Google accounts and T-Mobile Contacts Backup.
    5. Return to the Home screen.
    6. Open the App menu.
    7. Touch Contacts or People.
    8. If there are any contacts listed, they are stored on your phone (because you turned off the ones synced). From the menu, export them to the SD card to save them.
  4. Clear the app cache and data:
    2. Touch Settings.
    3. Touch Applications.
    4. Touch Manage Applications.
    5. Touch All.
    6. Select the application that is having issues.
      Note: For the following errors:
      • android.process.acore: Select Contacts storage.
      • android.process.mms: Select Messages.
      • com.google.process.gapps: Select Download Manager or Downloads (At the bottom of the list). Make sure the Downloads Manager is enabled. If it isn't, enable it before proceeding.
      • TWlauncher process com.sec.android.app: Select TWLauncher.
    7. Touch Clear data and Clear cache if they are available. This resets the app as if it was new, and may delete personal data stored in the app.
  5. If you turned off sync, return to Accounts & sync and turn it back on. If necessary, import any contacts you exported to the SD card.
  6. Uninstall all third-party party task managers, battery saver, or apps that close programs. For information, see Manage Applications: Manage memory on Android.
  7. Restart the device.
  8. Open the app to test if the problem happens again.
  9. If the problem recurs, uninstall the app (if possible).
  10. Wipe the cache partition to clear system memory.
    Note: To find steps for your device, search Support Community for: wipe cache [device name]
  11. Open Play Store, and re-install or update the app.
  12. Open the app to test if the problem happens again.
  13. If the problem recurs:
App never worked OR app received update and stopped working
If the app that is showing errors never worked OR was updated and then stopped working, then follow these steps:
  • If the error is with a pre-installed app, then look for more content in your device space or user manual.
  • If the error is with third-party apps, then contact the app developer. T-Mobile does not support third-party apps.
Mar 19, 2014 | Cell Phones
I had Microsoft Office 2007 on my computer, but I needed 2003 for something so I installed it. Later, I tried to open Microsoft PowerPoint 2007 and it always prepares for install, but then I get Error...
Hello slavena95
I am maybe misunderstanding you but if you are trying to use two different versions of MO on the same computer , this won' t work . If you are not , probably some files or keys of MO 2003 are still remaining in the registry , causing conflicts with MO 2007 .
To correctly and entirely delete a program , you should use a third party program such as the free version of RevoUninstaller from : http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Best regards ,
fanaudi .
Mar 24, 2011 | Microsoft Computers & Internet
I forgot the phon e(samsung sgh-m310) password for messages and files so i can't reset it. there is no sim card in the phone but it is a t-mobile. what can i do to reset it ?
Hello there, You may contact to your network provider Samsung SGH-M310 Unlock Code, they will provide you a code with easy to follow instructions on how t unlock your phone. I suggest to visit Samsung Unlock Code, they can open up all networks for you where you want to use your phone. Once your phone is unlocked, it will work with any networks worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
Mar 07, 2011 | Samsung SGH-M310 BLACK Cellular Phone
How can i unlock my files on my pone , i forgot my passsword
Hi there, You may contact to your service provider Samsung U900 Soul Unlock Code, they can open up all networks for you where you want to use your phone. You may visit Samsung Unlock Code site, they will provide an accurate code fast with easy to follow instructions on how to unlock your phone. Once your phone is unlock it will work with any networks worldwide without sticking to one network only.
Hope it helps.
Thanks.
Feb 09, 2011 | Samsung U900 Soul Cellular Phone
Whenever i download something and try to open it, it tells me that file type not supported.. how to fix this problem please
HI..
Your satio is based on Symbion O.S. Consider If u download a video file .wmv , it will not support u for that u have download video software for it. So, you ahave to download perticular software for perticular file type. Symbion O.S allow u to download third party software.
Feb 02, 2011 | Sony Ericsson Satio Cell Phone
Sony ericsson w350 cell phone
You don't need the software to transfer music. I have the software but don't bother using it as it takes much longer to transfer files this way.
Just connect my your 350i to your computer using the USB cable. On your phone select "file transfer". Now, go to "My computer" and after 30 seconds your phone should appear as a removable drive, and you can drag & drop (or copy and paste files) into the music folder therein.
While in "file transfer" mode you cannot make or receive calls or texts, so be sure to disconnect as soon as your file transfer is complete. To do so, in my computer, right click the icon for your phone and select "eject".
Nov 26, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
