Question about Tablets & eReaders
How to insert a som into huawei tablet? - Tablets & eReaders
How do I turn off offline on my Huawei tablet
It's simple you have to switch off data or wifi
Apr 19, 2016 | Huawei mediapad 7 s7 931u tablet
Removing cover to access sim
If you really don't have the skills to repair modern electronics, please don't try to open the tablet. You won't be able to open it in the first plase, without damaging the tablet. I think a technician, should be able to remove the sim, if it can be opened, with a pair of fine tweezers. But again, please don't try this yourself.
Jul 28, 2014 | Huawei mediapad 7 s7 931u tablet
Tablet instructions
You can find the instructions for how to setup your secure wireless connection in the Huawei manual. And in the little booklet that came with your Samsung you can read how to connect to Huawei.
don't forget to make a note about the name and password you gave in on the Huawei.
please don' ask me to type over these pages, because one way or the other, you have to read it. Better take the booklets.
Jul 22, 2014 | Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280...
How to unlock Huawei MediaPad 7 Lite locked after "too many patterns attemts" MediaPad, SpringBoard General. ... for this tablet s7-931w
First solution is to use Google account associated with mobile.You need to log in into your Google account and then you can disable or change the pattern lock.
Second solution is to boot into recovery mode and reset the tablet - you will loose all you data however.
The third solution is only for techies and involves using the Android debug bridge to reset the tablet - not for the faint hearted.
May 11, 2014 | Huawei mediapad 7 s7 931w wifi tablet
Huawei s7-931u not power
Use a pin and press the reset hole on the back of the tablet.
If that doesnt work:-
Check your charger it may not be working - plug into a usb socket and let it charge from the computer.
Apr 05, 2014 | Huawei Tablets & eReaders
Huawei mediapad 7 not charging when plugged in, battery gets hot but doesn't charge
Hi Susan, did you solve your problem. I have the same with my Huawei. If yes please send me the solution - e-mail Georgi.Fotev@abv.bg
Thank you.
Mar 16, 2014 | Huawei mediapad 7 s7 931u tablet
Unlock huawei ideos s7
Take advise: www.guaranteedunlock.com
Jan 04, 2013 | Huawei Ideos S7 Slim Tablet With 8gb...
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
