Question about GE Refrigerators
Display shows only 00 moving in a circular pattern. Sabbath mode works. Have unplugged the unit for 10 min. On gfe29hsd
  • 22 Answers
SOURCE: GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Posted on Dec 03, 2007
  • 91 Answers
SOURCE: Dacor ECD230 Sabbath Mode
You don't need to do anything special.
Quoting from Daco.com FAQ
"In our ovens, the cooling and convection fans do not turn off when the oven door opens. The lights also do not turn on. There is no timed shutoff on our ovens, either, meaning that once they are turned on, they will stay on until you manually turn them off. Both of these would be considered violations. Our ovens do not have a special Sabbath button because our ovens already adhere to the laws. When the oven door is opened, there are no changes to the control panel, which would also be a violation. It is best to wait for the small "On" light with the circle around it to go on before opening the oven door, though. This light indicates that the element has gone on, as the oven cycles on and off to maintain the selected temperature. Opening the oven door without this light going on may trigger the element to go on, which can be a violation."
Posted on Mar 25, 2008
SOURCE: air conditioner
I managed to find the people who supplied the unit, it was still under warranty, and they said it was the thermistors (temprature probes, they replaced both of them) It is now working perfectly!
Posted on Sep 24, 2008
MNTECH
  • 1543 Answers
SOURCE: Sabbath mode
This feature has to do with when it is OK to cook during the Sabbath or some other Jewish holidays. If you are not of the Jewish religion, ignore it to allow your range to function 100 % of the time. Do not rate if you do not feel this is a Fix-Ya for your range, as other ratings will lower my score. Thanks.
Posted on Jan 20, 2009
SOURCE: Timex 1440 sports watch - the digital display is
How can i fix the time on my watch it is an hr behind and i lost the directions.it is a timex 1400 sport. it is pink and gray.
thank you
heidi
Posted on Jul 16, 2009
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum
forum.appliancepartspros.com/oven.../2348-maytag-oven-weird-error-code-5ab.html Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ...
https://www.shopyourway.com/questions/1098960 Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from www.shopyourway.com
Maytag Oven SAb error code - YouTube
? 0:54
https://www.youtube.com/watch?v=XUP1BOzqPUo Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
Baking display malfunction
Its likely sab as in Sabbath mode.
Here is your online use & care manual which explains all about the Sabbath mode on page 15:
http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf (http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf)
Mar 23, 2008 | Maytag MGR5750 Gas Kitchen Range
My Frigidaire refrigerator is showing the code 5c 5b on the front panel. What do this mean
Hi Juanita,
I'm not sure what the 5c code is however the 5b code means "Sabbath Mode" (Sabbath Mode is a feature that disables portions of the fridge and its controls in accordance with observance of the Sabbath and religious holidays within the Orthodox Jewish community)
You need to press and hold the arrows ("?" on freezer temp and "?" on refrigerator temp) to remove it, if the arrows are not lit up, press them anyway to try and get the fridge out of Sabbath mode.
Hold down both arrows for ten seconds to get out of Sabbath mode.
If that does not work, unplug the fridge for 10 minutes, plug back in, and try once again.
Edit: On newer models the press points are different: Sabbath mode is turned ON and OFF by pressing and
holding "Control Lock and Power on/off buttons" for five seconds...
Hope this helps.
Oct 11, 2017 | The Computers & Internet
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
Why is my Display not working?
I think that is a trouble code google applaince depot and call them and the can help u bettet
Jul 22, 2014 | GE GFE29HSDSS 28.6 Cu. Ft. French-Door Ice...
The digital read out shows 56 will not reset will not despense water or ice
Good Afternoon Friend,
I understand that you are receiving a 56 code on the display of your Frigidaire refrigerator, model# FRS26H5AS. I also see that it is not dispensing ice or water, even though you have reset it by unplugging it. The 56 is actually SB. This tells me that your refrigerator is in Sabbath mode. To exit the Sabbath mode, press and hold the down arrow and the plus sign, simultaneously for 5-10 seconds or until the display changes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire FRS26H5AS Side by Side...
Frigidaire Gallery side by side error codes
SB is in "Sabbath Mode".
of the refrigerator and its controls .
and holding both the freezer "down" and refrigerator "up"
indicators for five (5) seconds. The display shows "Sb"
Jul 04, 2013 | Refrigerators
I cancelled the clean proprocess and then the display shows 5ab and I can't get the oven to work or clock .. anything, no beeping
somehow you put it in sabbath mode,yes sabbath mode,a feature known as "Sabbath mode." According to the Jewish Sabbath law, raw food may not be cooked on the Sabbath, but food that was already cooked beforehand may be kept warm until mealtime. On Jewish holidays, food may be cooked fresh, but turning the flame on poses a problem given electrical requirements forbidden by Sabbath observers.try holding the clck button in for 3 to 5 seconds to take it out of sabbath mode
Mar 27, 2011 | Amana Kitchen Ranges
Have a Electrolux refrig. french doors and bottom mount. model ei23bc56iso Its shut off. The display in front at the dispencer says OFF at frezzer side and OFF at refrig side. No other displays or error ...
  1. Bottom Mount Refrigerator Ice Maker. When the bottom mount refrigerator is placed in Sabbath mode the ice maker will be automatically disabled. Please be aware however, that although you have entered the Sabbath mode, the icemaker will complete the cycle it had already initiated. The ice cube compartment will remain cold, and new ice cubes can then be made manually in the freezer section (using a standard ice cube tray) as needed for that Sabbath/Holiday.
  2. Sabbath Mode and the Perfect Temp Drawer (if equipped). The Perfect Temperature Drawer should be turned off for the Sabbath/Holidays. Before putting the refrigerator into the Sabbath mode, turn the Perfect Temp Drawer off by pressing the drawer on / off button. The display will show "OFF" and the drawer will turn off. Then enter the Sabbath mode function on the main refrigerator display. The drawer display will now not illuminate and the drawer will remain off until Sabbath mode is exited and the drawer is turned back on. The drawer can still be used as a non temperature controlled drawer in this mode.
  3. Press the display button few seconds and recheck.
---------- Check out thanks.
Aug 27, 2010 | Refrigerators
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
