Question about Garden
Lost bolt on craftsman snowblower model 950521311. Only the left wheel drives at this point.
2 Suggested Answers
  • 2944 Answers
SOURCE: Lost bolt on right wheel of craftsman snowblower modelC959521311. Only the left wheel drives at this point
I typed in your stated model number into the website of SearsPartsDirect and they say you are missing a number or two or three.
If you could provide that website the whole number, they should have that part you need and can ship it to you.
God bless your efforts.
Jan 02, 2017 | Garden
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
How to put click pin back in craftsman snowblower
Open pin, Separate pin from circle. Insert pin into hole of drive wheel, the close circle unto pin.
Feb 15, 2013 | Craftsman 155443 Click Pin
Lost drive on poulan pro snowblower
The auger isn't moving or the drive wheels aren't moving?
Jun 18, 2017 | Poulan Garden
Snowblower stalls without reason and now makes a squeeling noise. craftsman 8.5 hp model 536.891851
Check the drive belts at the engine for wear or damage. It could also be a bad bearing at some point in the auger/impeller or wheel drive. Try to pinpoint the source of the noise and what you do that makes it squeal. Good luck!
Jan 22, 2011 | Craftsman Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
My Craftsman 26" 9HP snowblower pulls to the left. Any ideas?
You likely have it in one wheel drive,try lifting the rear wheals of the ground to check and see if both wheels tirn at the same speed.If they don't then you need to change the wheel that is not turning into a drive wheel by removing the pin and putting it back in in the lock position[usually the next hole back in the axle].
Jan 07, 2010 | Craftsman 16" High Garden Tractor Snow and...
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
Screws on my Sears track drive snowblower unthread themselves.
Back wheels have a gear that connects to the drive chain. on each side. those spin.
The front ones which are Idlers do not spin as the idler wheel as a bushing in it that allows free motion on the shaft without resistance. Use a nylock nut with Locktight for starters. The try that.
Hope this helps. -Jeff anchorage small engine repair.
Feb 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
