Boiler will not fire e5 fault - Heating & Cooling
2 Suggested Answers
SOURCE: fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Posted on Dec 01, 2008
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Jan 31, 2012 | Heating & Cooling
New sime e comfort 25HE boiler problems
It not wired in right that why its coming on when it is off The boiler is over riding the programmer when it is off .
The boiler should call for heat if programme is on it sounds like boiler is wired into the 24hr mode or over ride mode that why it is coming on . google wiring for y plan heating system. this will help you fault find on this . changing vales and thermostats will not help you . Hope this helps .
Mar 05, 2017 | Water Heaters
F4 fault with Vizo Plus 24. Not condensation tube as this was changed to new tube with sensors on ''blue plug'' by engineer last year when I called them out for re-curring F4 fault - new sensors are bone...
Hi, if the ignition module fires or tries to fire 4 times, this indicates the module is faulty and locks out for safety reasons because of an internal fault.The f-4 code sounds like the pressure switch was open due to condensation not letting it fire up, so the switch was ok, so they changed out the tubing. When you re-set the boiler control module, it locks out due to a internal fault. Change it out and you will be back up and running. The electrodes from the module will cause this as they come from the module. Make sure the condensate trap has no blockage at all as this can cause this problem. I am not guessing, I would replace the boiler module control that you have been re-setting. Keep me posted,
Sincerely,
Shastalaker7
Mar 18, 2010 | Heating & Cooling
I have an ideal standard he30 boiler instaledi have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip...
You have a problem that the installer does not know how to fix so they are just stringing you along hoping that you will give up and find some one else or forget about it..
You need to tell them to
1. fix the boiler correctly
2.take it back out and give you a new one at their expense
3. or tell them you will call another comapny to fix it and will give the bill to them to pay.
You did not get what you have paid for... do not pay them any money to come out and troubleshoot the boiler.
The boiler should work as the instructions say or someone did something wrong...
Sometimes it is best to call the boiler company and talk directly to their Tech. Support people.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 24, 2009 | Heating & Cooling
Fault light flashing 1 flash per second
Nov 30, 2008 | Bosch Water Heaters
Ariston eurocombi boiler not firing up. Thermostat lights all on upto 80 degrees as if overheating. Pressure fine. No fan, no ignition.
The fault occured a few days after I altered the radiator layout and then refilled the system. Intially the boiler worked fine, then a few days later all of the temperature lights light upto 80 and the boiler would not fire. The pump was working but the fan was not. After diagnosing the electronics I came to the conclusion it was either the contol pcb or the temperature probe. As the temperature probe was the cheaper option I replaced that first. The system is now working again. I think this fault was caused by me failing to completly remove all air from the system after refill and an air lock occuring causing the probe to burn out.
Nov 26, 2008 | Heating & Cooling
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
