Model md260va, picture goes out beyond edge of screen in normal mode, trying to shrink it slightly
    New Friend:
  • 22 Answers
Try adjusting resolution or picture ratio
My tv scren has been shrink, how to return it to the regular size. thanks
Try:
Main Menu - Picture - Screen Settings - 16.9 Overscan - ON
This mode displays the image for 16.9 aspect and when on enlarges the image to hide the edge of the image.
Good luck.
Sep 26, 2014 | Samsung Televison & Video
Picture of the tv shrinks to half
Could be a failing power supply. Not surprising after 10 years of use
Mar 22, 2017 | Televison & Video
Slight color changes on both sides of the screen
What you have , sorry to say is burnt CRT's this is caused by watching tv in the 4.3 mode , which shrinks the pic on both sides. so now the phosferous on each crt is only use in the center, that leaves the outer edges fresh and as new
There is no way to fix thin outher than replacing the crts sorry
Nov 23, 2009 | Televison & Video
Picture tube going out?
Not ur tube.Ur convergence,dying or be dead.U need a convergence kit.U know how to solder right?Replace what in that kit.Tries these websites.Tv Repair World.com
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Optimal resolution problem, edge of desktop outside screen
Your screen probably wont recognise the dvi cable if the dsub is plugged in, you will have to use the buttons on the monitor to adjust the settings to dvi rather than it automatically using the dsub. also, ever tried adjusting the aspect ratio? to make it shrink abit to fit your screen.
Sep 25, 2009 | LG W2261V 22" LCD Monitor
Picture stretched on right and left edges.
I have a 32 inch Akai that does this from the built in DVD player mode I would try to get into the advanced video options on the menu I don't have a remote so I can only advise that far
hope that helped some.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
Picture and text extend beyond screen
Your tv needs to be put into service mode with the original Sony remote control and then set the vertical\horizontal size parameter to the correct values and then burn the new settings to memory
Google " sony tv service mode " and you should find the procedure. Good Luck! Write back if you have problems.
barneyluc
Oct 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture problems
if it's Narrow on both sides, height and width vary with scenes
try replacing C4407, CR4403
Jan 02, 2008 | RCA P46921 46" Rear Projection Television
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Tv has lost two outer sides of vision despite changing picture mode
That's either a high voltage problem, or a deflection problem. WARNING, CRT Based Televisions have potently life threatening voltages inside them, and should be serviced by trained personnel only. With that out of the way. According to http://www.repairhelper.com It's a capacitor failure Fault - Width and E/W correction fault Remedy - Replace R626 and C630 I don't have a manual so I can't tell you for sure what the resistor and capacitor do, or where they are located.
Dec 30, 2006 | Bush WS6671 28" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
