Question about Water Water Heaters
My fresh water tank will not drain it drains from the hot and cold water drains and the water pump is on
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 20 Answers
Where is this fresh water tank?
Posted on Jan 10, 2017
  • 104 Answers
SOURCE: how to drain hot water heater
look under camper at floor
Posted on Nov 11, 2008
  • 252 Answers
SOURCE: Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
Posted on May 24, 2009
peterrance19
  • 399 Answers
SOURCE: I think I need to drain/flush our hot water heater
hi first making sure not to burn yoursel switch of heater and drain down down water from taps this may result in causing an air lock dont worry ! at the base of the heater you have the stat and element housing first withdraw the stat then the element alowing any remaining water to drain when fully drained turn on your water supply to flush out and clean replace element and stat using plummers sealent or tape hope this helps
Posted on Nov 16, 2009
heatman101
  • 43501 Answers
SOURCE: sounds like a squirrel inside water heater
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Posted on Mar 25, 2010
SOURCE: Water is leaking from the
Easiest to put hose cap over end of drain.
Open following link for resources and illustrations:
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Posted on Aug 13, 2011
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
Low flow trough the heater
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electric panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on.
Test and replace a relief valve:
  1. Lift the spring lever on the valve to fill a small cup. Check the cup for sediment.
  2. If no water spurts out, or if water continues to drip after the valve is released, replace the valve.
  3. Cut power at the electric panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
  4. Drain a few gallons of water from the tank.
  5. Unscrew and remove the discharge pipe if used.
  6. Loosen the relief valve with a pipe wrench, then remove the valve by hand.
  7. Apply pipe tape to the threads of the replacement valve and screw it into the tank by hand. Tighten it with a pipe wrench. Screw the discharge pipe (if any) into the valve outlet.
  8. Refill the water heater and restore electrical power.
Oct 08, 2013 | Water Heaters
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
Low water pressure
Hi Bob,
You can determine if the tank is the problem by connecting a garden hose to the drain that is provided on most water heaters. Before doing this, be sure to shut of the electrical supply to the heater - otherwise you can damage heating elements if an electric type or waste fuel by heating an empty tank if a gas / propane fired type.
If you get a slow flow out of this drain, it means that somewhere in the cold water supply side to / in the tank - there is a problem. Inside the tank, the cold water is delivered by a "dip tube" that distributes the cold water to the bottom in the tank. Dip tubes are used in both electric and gas / propane fueled heaters. Here's a cut away view of a typical tank:
If the tube is clogged, or there is build up, scale or debris in the supply (cold water) side of the heater, flow rates will suffer. Likewise, if there is a problem with the output of the tank, it will directly affect flow as well.
If you get a good flow rate from the drain, then the issue is going to be on the hot water output side of the heater. Again, the same build up, scale, debris issues on the hot water out put pipe will cause problems with flow. Typcial tanks do not have dip tubes for the hot water side of the tank - as taking hot water from the top of the tank is most desireable and is furthest away from the cold water that rushes in to make up the hot hot water going out.
There's nothing really in the tank itself that can cause issues with flow outside of the dip tube, and piping to and from the tank.
Jun 29, 2012 | Water Heaters
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Cold water ok, no water flow from hot water lines.
Bypass valve incorrectly set
obstruction or dirty tank
plugged line - lime or other! does cold flow into tank ok?
Tank is split water going somewhere you can't see - this should be obvious.
There is not really anything to obstruct the flow normally so there
would have to be an obstruction somewhere. Lime, junk, garbage etc build up .
On my coach I have lots of pressure on the cold side so hot would have to have the same unless there is an obstruction into or out of the tank. If in the bypass position you have sufficient flow than the lines are ok and the problem or obstruction is in the tank itself. Drain the tank, leave the bottom plug out, open up the pressure relief valve. Turn on the water and see if you get a lot of water draining from the drain hole on the tank. There should be a lot of water coming out of the drain hole. If so that tells you that your getting sufficient flow into the hot water tank. If so your problem is the water getting out of the tank. Like a clogged return line or an obstruction from the water tank to the faucet. A dirty scale lined tank can do a number on tank water flow. Also check to see if the water is going somewhere else, your tank could be split and you just can't see where the water is going!
Dec 17, 2009 | RTO Atwood Water Heater - 6 Gal LP
Draining the Priemer Plus Gas Hot Water Heater
Begin by turning off the gas at the tank and at the valve near the tank. CAUTION: Do not proceed any further if you do not know how to relight the gas pilot!
2) Turn off the COLD water supply to the tank.
3) Attach a garden hose to the drain valve at the bottom of the tank. Run the hose to a convenient drain location. Be careful if you use a real cheapy garden hose... some of these become very soft when hot water runs through them, and may leak! If you don't have a drain in the basement floor or suitable sump hole, you have my sympathies... this drain-down can take a while with a bucket! Oh... and be careful if you use a soft plastic bucket. It can also soften from the heated water so don't overfill it or burn yourself!
4) Open up the hot water side of any faucet. Open up the drain valve on the tank and allow it to empty. Miller time. That is, unless you don't have a sump...
NOTE: If the drain valve clogs, turn on the cold water supply to the tank to use water pressure to "blast" through the clog.
5) When the tank is empty, shut off the drain valve and turn on the cold water. This will loosen up more sediment in the tank through the churning action of the cold water in the tank. Let the tank fill partially and drain it again. In fact, if you find that the sediment starts to clog the drain valve, turn on the cold water supply to the tank, which will help loosen the sediment and blast it out.
If you have extreme amounts of sediment, you may have to repeat this procedure a few more times. Look at the drain water... if it is running clear, you are done. Shut off the drain valve, open the cold water supply and allow the tank to fill. Once water comes out of the hot water faucet, the tank is full and your task is done! Now, you can turn the electricity or gas back on to heat the water.
How frequently to clean the sediment from your tank...
This depends on the source and purity of your water supply. Some pros recommend doing it annually, some every few years. I would recommend doing a partial drain down annually if you find any sediment in the tank, otherwise every couple of years.
Remember that with an electric water heater, you must turn the power off! Even a partial drain down may expose the upper heating element to the air and permanently damage it!
Jan 21, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
