Question about Coffee Makers & Espresso Machines
Coffee spout will not stay up - Coffee Makers & Espresso Machines
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Water does not dispense through the coffee spout
Did you cheak if the spots are blocked did you run some clean water ? The milk further is a different section from the coffee try and consentrat on the coffee part run some clean water is there any noise is the water going in to the trip tray because the spout are blocked ? Next go inside and cheak driver relay or seloniod stay safe if you not such don't do it
Jul 06, 2014 | DeLonghi Magnifica Coffee Makers &...
Only one spout dispenses coffee
Same for my CVA 5060 : the right spout seems to be blocked...
I tried a cleaning cycle and a descaling one with no success.
Any idea of where to clean ?
Apr 13, 2014 | Miele Coffee System
The brewer unit light seems to stay on and the coffee maker wont respond when pressing the coffee dispense buttons
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, (use a food grade lubricant) so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Aug 13, 2011 | Saeco Magic De Luxe Espresso Machine
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
The coffee spout is pouring into the coffee pod collector
I have the sameproblem, I suspect something is blocked but I don't know how to remove the spout????????? Please helP!!!!!
Feb 08, 2010 | Nespresso C100B Essenza Single-Serve...
Both spouts seem clogged
I have a Jura Impressa F7 that had the exact same issue. To solve it was pretty simple. Try and make a cup of coffee, and while the machine is trying to pump the coffee thru the spouts, grab the chrome handle on the spout and vigerously move it up and down rapidly. You should notice small grounds of coffee dislodge and follow the stream of coffee into your cup. If you do this a couple of times, you will be able to clear the trapped grounds within the spout. Hope it works for you as well as it worked for me.
Jun 23, 2009 | Jura Capresso Impressa F9 Espresso Machine
Drips onto counter when pouring from carafe
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Mar 02, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
