Question about Humidifiers
Error code EE on aircare Ep9 800 humidifier? What is it and how do I fix it?
Why is my Aircare tower humififier flashing CF??
clean filter, filter is blocked not letting the air flow through correctly, take the filter out and clean it with warm water and leave to dry before refitting, can use soak but not to much as can damage the filter threads. but warm water will do the job to remove the particles its picked up.
Jan 16, 2018 | Humidifiers
AirCare.condole evaporative humidifier, won't run, shows EE code.
If it has a humidistat in the power cord it may have gotten wet when refilling. Blow the water out, or remove the screw to open the small casing and dry it out. If it was wet, the unit should start running normally.
Dec 08, 2016 | Humidifiers
How do I fix water valve?
Find a replacement on there website.
Jan 01, 2016 | Crane Frog EE-3191 1 Gallon Humidifier
Looking for manual HM1865
This link should open the manual for you. I covers both the frog (the model you have) as well as many others. http://cache.air-n-water.com/manuals/crane-ee-3191.pdf
Mar 03, 2014 | Crane Frog EE-3191 1 Gallon Humidifier
Why does the crane elephant humidifier leak
The humidifier has just started leaking from underneath the trunk part and drips down the front side and pools quite a bit underneath the humidifier causing quite a wet mess. This just started after I ordered a replacement water tank. Any suggestions?
Feb 15, 2013 | Crane Elephant EE-3186 1 Gallon Humidifier
I need the instruction manual..i don't have it and i don't know how to operate the humidifier
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
This is the manual for all "adorable" crane humidifiers.
Nov 12, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifiers Logo
292 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
