Are there reports of SE32HD01UK freezing under normal use, with only solution being to switch off at plug.
When it freezes the picture and audio continue as normal, but we cannot change channel , volume or enable youtube. If we are on youtube when if freezes again it continues as above but again there is no response to either the remote control or the buttons on the TV itself. Even pressing the TVs on/off button has no effect and the only solution is to switch off at the plug. Help
techman
  • 3130 Answers
SOURCE: Video will not turn off; "I2C-BUS STOP MODE" error at power up
Nope a very easy problem .. What it is is the relay is stuck on or closed so when you plug in the set the power comes up But the micro hasent told the rest of the set to work yet. So when you hit the power button. its just like you hit the power and it activated the relay and the rest of the set. Now in some rare occasions the driver transistor for the relay was shorted But most of the time its the contacts that weild shut, but you cant just clean them as it will work for a while, but in a month or so you will be in the smame boat. But if you not a tech this repair shouldnt cost you to much because if your not an experienced tech you can not only cause harn to the set but also you yourself BE CAREFULL and take the set to a pro!!!! Good Luck
Posted on Jul 27, 2006
  • 192 Answers
SOURCE: TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Posted on Apr 01, 2007
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 197 Answers
SOURCE: Volume turns itself to maximum
soft waer call phillips
Posted on Jun 07, 2009
Volume goes up, picture freezes, tv reboots
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Apr 22, 2014 | Vizio E421VA 42 in. LCD TV
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
My picture keeps freezing and the sound jumps
solution
step 1 : test your fly back transformer
step 2: Test audio I.C. and more test were test by the A.V.O. miter step 3 : A.C. transformer out put voltage test
step 4 : contrast control switch test ,If luce contract
Send report :babul_jpi90@yahoo.com
thankyou
please send me only one vote
Jul 28, 2011 | Televison & Video
Where are my freeze plugs located on my 1996 gmc yukon? i have water shooting out right under the a/c compressor seems like its coming from inbetween the valve cover and intake
more than likely it wouldn't be the freeze plug but normally the these vehicles leak from the intake or the fitting for the heater hose going into the intake. but as far as freeze plugs there should be one behind the a/c compressor somewhere close by
Jun 02, 2010 | 1996 GMC Yukon
1991 (4 cylinder) Toyota Camry freeze plug problem
the price is determined by how much you have to remove in order to gain access to the freeze plug to replace it the freeze plugs themselves are just a couple of dollars but could be several hundred to replace due to gaining access to replace you also have freeze plugs sometimes that are on back of engine and require you to either remove engine or transmission to replace also keep in mind that normally if a freeze plug is leaking it is due to a neglected cooling system that is now full of rust that may have to be flushed out
May 03, 2010 | 1991 Toyota Camry
Diesel engine won't start in freezing temperatures
Verify each glow plug and replace burned glow plugs! After 7 years it is recommended to replace all engine glow plugs (complete set).Check also the glow plugs relay and replace if necessary!
Feb 14, 2010 | 2002 Mercedes-Benz C-Class
Sony lcd tv picture freezes
I saw the solution posted to your problem talking about the picture freeze feature on Sony TVs. I presume you're not touching a button on the remote when your picture is doing this.
Normally when a picture freezes it isn't the TV but the signal the TV is receiving from whatever source it's hooked up to. If you have digital cable and the company is having any type of technical difficulties with their signal, it can cause the picture to freeze. If you've ever watched TV with someone who has Dish or DirecTV while a storm was over-head, you may have seen it happen to their picture. However, if you're able to rule out the cable equipment and the cable company as being the problem, then there is something wrong with your TV. If your TV has this picture freeze feature the other guy was talking about, it's possible the feature is now malfunctioning . Whatever the case, if it's the TV the only troubleshooting you can try is to unplug the unit for 30 minutes. If that doesn't fix the issue, the TV likely needs to be serviced. Follow the link below and it will take you to Sony's esupport page. There you will find a phone number you can call, or you can chat with someone online regarding your particular issue. Good Luck!
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Aug 04, 2009 | Televison & Video
X box stays on and telly blurryy but showing the picture?
It sounds like bad soldering, your tv doesn't freeze it's your xbox video/audio output that does. Did you use the towel trick, that is one possible way to have gotten it. You should send it to Microsoft for repair.
Mar 14, 2009 | Microsoft Xbox 360 Console
Picture freezes and no sound or sound and pictures normal
Okay,only one thing you could check,and that would be your electrical outlet.Using another outlet from a different room(power extension cord) to plug your TV and see if it does the same thing.
If it does,don't bother,you need a repair serviceman to take care of it or if it is under warranty,call your retailer!
solutiondoct
Nov 11, 2008 | Samsung HL-R6167W 61" HDTV
Split screen, dark and then light, picture freezes
From what source ? Does it happen when you play a DVD ?
Cable direct? Cable box? Satellite box?..........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Televison & Video Logo
Top Televison & Video Experts
