Question about Stoves Ovens
Hi I have a Stoves Envoy 850 DODLM; double oven,serial number 050567006 I need to check what the door seals look like and the glass doors themselves,how many pieces of glass per door? Can you help
onthejob5130
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
  • 17 Answers
SOURCE: cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Posted on Feb 04, 2009
  • 250 Answers
SOURCE: Stoves 900GDO Bottom oven door seal
The handbook tells you how to take the door off. If you can do this, do so and then clean/spray all the door hinge mechanisms with WD40. Remove the surplus with kitchen towel and replace the door. Operate the door a number of times to see if this has cleared the problem. (Over time the hinges seize up and the WD 40 normally eases this situation).
(Don't be confused with the air flow coming out of the oven from the cooling fan as this also runs along the top edge of the door).
Posted on Apr 04, 2009
ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
SOURCE: Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Posted on Dec 12, 2010
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
I want to change the door seal on the pyrolitic section of my double oven. its 15 years old and I believe I need to take off the door to achieve this. I also need to clean the glass inside. There is n
Should. Find few screws on the top and the sides of the door. Just unscrew them and see how the old one is that will give you a clue on how to replace it.
Jul 25, 2012 | Stoves Ovens
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
The hinge on the main oven door of my heritage 900ef needs replacing. Where can i buy one from please
Well, you can try STOVES and see what they will charge, and/or try espares. Once you have the part number, google that to see if anyone else can supply.
You may want to think about replacing both hinges and the springs at the same time, to ensure the door works/closes properly. Also, check the rubber seal round the door, then tend to become brittle when at the end of their service life, so it may pay to include that with the order as well.
Apr 12, 2010 | Stoves 720EF Electric Double Oven
The glass has shattered in my electrolux eou6330x door
i live in az here i use aplace called appalince depot . check phone book or net for something similar
Feb 22, 2010 | Electrolux EOU6330 Electric Double Oven
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
Grease between glass in door after self cleaning mode
As you can see on the diagram below, for the model in title, the door glass is sealed.
Gaskets and sealings are often not covered by regular warranty.
Call the manufacturer at the number listed on your owners manual to check if they can cover the door glass and sealing replacement.
You find all parts and diagrams for model listed in title here.
Mar 02, 2009 | KitchenAid Architect Series KEMC308KSS...
You will probably have to replace the oven door hinges.
This should solve the problem
Dec 02, 2008 | Stoves 720EF Electric Double Oven
Open Questions:
Ovens Logo
62 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
