Question about Mitsubishi MS12TN Air Conditioner
Mitsibishi ceiling box
Heater does not work also it does not blow air the iarflow wings do turn only fan works when using fan
  • 104 Answers
Check your switch,maybe you have a defective switch.
Posted on Jan 21, 2008
Why won't my ceiling fan blow air down anymore no matter what direction it turns
sounds very intriguing really, like some body has played the
practical joke of turning the blade assembly upside down.
Just an onservatio. Can the blades be removed and replaced upside down? please let me know what you discover, it sounds very interesting
Jun 03, 2015 | Hunter 21894 Westover Four Seasons 52-inch...
Turn on power to heater & nothing but the power light comes on, please help
There's a heater core box where radiator coolant passes through. When you turn on the heater, the fan on the heater core box blows air through the core, then the air is heated up and it passes through the air ducts, which leads to the windshield defroster, the vents, or your feet depending on where you set the control. If you're not feeling heat, either the fan on the heater core box is not working, or there's restriction on the coolant hoses and hot coolant isn't passing through the heater core box. Remove and diagnose the heater core box to ascertain the coolant lines are not blocked and the fan is fully operational. If the heater core box is OK, then the hoses have restriction to prevent hot coolant from passing through the heater core box.
Nov 26, 2013 | Plymouth Voyager Cars & Trucks
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
My new rieker fan stopped blowing heat- the fan works --not the heater
I had the same problem with my fan and solved it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat, even though the heat doesn't work. Then, leaving the remote on, turn off the fan at the wall switch (or circuit breaker box). Wait a few minutes. Then turn on the power and within 30 seconds, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat started working again.
Jan 05, 2011 | Reiker Ceiling Fan/Heater Combo Utility
Which way should the fan turn for winter use?
Although there are those who would say otherwise, it really doesn't matter much which way the fan turns regarding summer or winter. It does matter regarding whether you want air blown directly down upon you or sucked up past you toward the ceiling. Some would say that the fan should blow down in the winter, since hot air rises and the fan would blow it back down, but if you think about it, if the fan is blowing air toward the ceiling, the hot air up there has to go somewhere, like down when it reaches the walls. It is, once again, really a matter of what makes you comfortable in summer or winter.
Hope this helps.
Oct 07, 2009 | Hampton Bay 24002 Ceiling Fan
Ceiling fan does not blow air
I would guess that the blades are on upside down. Ceiling fans are not supposed to work the same as desk fans though. The idea is not to create a strong flow of air but to create a "cooling breeze" by speeding the convection currents. They work better when they are running slowly (like you see in the old movies)
Sep 19, 2009 | Hampton Bay 24002 Ceiling Fan
2001 tahoe front heater not working, rear heater blows warm air
I have the same problem with my 2001 Tahoe. The front blower is working, its blowing strong, but its cold air even with the temp setting as high as it can get. The rear blows hot air. The engine temp guage is at about 210ish which is close to being normal (220). I just replaced the thermostate a few months ago, I don't know if its bad again, or it I deluted the antifreeze too much and it frooze the heater core, or if the heater core just went bad. Any one know what the cause could be?
Jan 05, 2009 | 1998 Chevrolet Tahoe
Air condition
Check the following fuses:
10 amp GAUGE under the dash, and the 40 amp HEATER under the hood.
If both fuses are good, I suspect that you may either have a bad fan switch or a bad heater fan motor. The switches are rare to fail, I would suspect the heater motor first. Please try this: Turn the key on; turn the fan switch to high. Look under & behind the glovebox, for the bottom of the heater fan motor. Round thing with 3 screws holding it to the heater box. Using a small hammer, or something that you can tap with, tap on the bottom of the heater fan motor. You just may jar the motor enough to make it run. If it comes back on, you may need to replace it at some point in the near future. Worked for me quite a few times. Try that, repost to me what happens. Hope this helps.
Oct 10, 2008 | 2003 Toyota Corolla
Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Aug 16, 2008 | Hampton Bay 24002 Ceiling Fan
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Mitsubishi MS12TN Air Conditioner Logo
35 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
