Question about Home
Pressure cooker not building steam up - Home
  • 10865 Answers
SOURCE: how do you seat the steam vent on the pressure
hi i can help you. the steam vent on these appliances automaticallyopen and close as need be. you do not have to seat them.
Posted on Jul 04, 2009
  • 22 Answers
SOURCE: Leaks near handle, won't build up steam to pressure
I just got a Saeco Aroma that has this issue, so keep that in mind as it may not apply to your machine.
Two things can cause this from what I can see: a defective brew head gasket (if the machine is very old the rubber can crack) it can crack) or a defective outlet valve.
In my case it was the latter: you need to remove the screen, then access the vallve body. On the Saeco, you simply unscrew it with a quarter. Inside is a stainless steel spring and a valve that would normally sit on the internal outlet tube. Mine was simply broken in three pieces. That makes it impossible to properly build pressure during warm up and, forces water up into the tank all the way to the top which them mixes with the steam during steaming.
The outlet valve, spring and valve body  is a maintenance item that can be bought as a kit online for about $25. Or you can get the whole set of gaskets, o-rings, valve and spring for about $50 if like me you just got yourself a machine that simply needs its 5 year overhaul.
This outlet valve replacement is a 'one wrench' repair that can be easily done by any reasonably skilled handyman in less than 15 minutes.
Good luck, hope it helps putting it back in service if you still have it ;)
Posted on Mar 18, 2010
  • 1739 Answers
SOURCE: need a steam release valve for my Bristo Wolfgang
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
Not sure if your model is the BPCR0175 but if the part you require is not available on-line suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Posted on Apr 01, 2011
RyanFanMan
  • 342 Answers
SOURCE: Still very new Tedelex pressure
My pressure cooker does that too, you would have to wait until the steam starts to come out a lot, then it will pop out and start building up pressure. Hope this helps.
Posted on Apr 08, 2011
miguel180
  • 4 Answers
SOURCE: pressure cooker not building up pressure
Shanihulugal- please contact us at 1800-207-0806 x 127 or at: info@fagoramerica.com
We will replace the pressure cooker pot if the unit is defective.
Thank you.
Posted on Jun 08, 2012
Steam is escaping
The valve should be seat to sealing. When the cooker is coming up to pressure it is normal for the steam to push oxygen out of the valve. Then, once it has reached pressure and the cooker starts to count down the cooking time the steam will stop coming out.
http://www.hippressurecooking.com/recent-forum-posts/
Feb 08, 2014 | Emeril from T-Fal Emeril Lagasse Electric...
Steam release doesn't work
When the cooker is reaching pressure, the valve should point to the dot, and after pressure cooking, you turn the valve towards release. The valve will feel quite loose, but it if it's in the wrong position when the cooker is reaching pressure then the cooker cannot build, and consequently will not release, pressure.
Here is the manual if you need more information on how to operate the cooker:
http://www.hippressurecooking.com/t-fal-emeril-lagasse-electric-pressure-cooker-manual/
Feb 01, 2014 | Tefal Emeril by T-fal Electric Pressure...
7qt bistro elite pressure cooker will not preasurize
PLEASE make this test with multimeter for fix it. God bless you
If the appliance does not heat, make sure that power is on at the outlet and test the power cord; replace it if needed. If this doesn't work, disassemble the unit and test the heating elements .
Nov 08, 2013 | Wolfgang Puck Bistro Elite 7 Qt Electric...
Why is there steam pouring out of my pressure cooker when I start to cook a piece of meat? Is that a sign that something is wrong?
Don't worry - it's a sign that your pressure cooker is doing what it's supposed to do. When you first start cooking the pressure is too low to activate the red center which is the overpressure valve. The steam coming out is just a way of getting rid of any cold air that's inside the pressure cooker. If the steam continues to escape later on in the cooking process then you need to check that your overpressure valve is clean and that the red center button is in the correct place.
Feb 14, 2013 | Home
Pressure cooker not building up pressure
Thank you.
May 31, 2012 | Fagor Duo Pressure Cooker 4qt
Still very new Tedelex pressure cooker: the red-headed pop-up valve seems to take for ever before "popping" and allowing steam pressure to build up. How long should I wait? Thanks, Nic
Apr 08, 2011 | Crock Pots & Slow Cookers
No.1 part, the round whistle in the middle of the lid doesn't pop up when the cooker is on and pressure is building up instead the steam comes out of small pressure ball and it sprays everywhere.
Here are detailed instructions on how to use it. It sounds like the slide on the handle was not set to the locking position:
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Mar 22, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
The seal on pressure cooker #99700 leaks after pressure builds up and a dangerous amount of steam is expelled . we were almost scaled by the steam.
>>> Please leave feedback so I can continue helping You & Others
make sure the pressure relief valve is working, not blocked etc, if it's OK try replacing the seal.
Thanks,
Adam.
Feb 19, 2011 | Vacuums
Error code keeps flashing wont pressure up and they wont stand behind their product
The vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Mar 09, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Jan 16, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
