Thermostat set at 73degrees , turns on and off to frequently
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
There are two reasons thermostat is defective or is located correctly the second check timer setting
Posted on Jan 03, 2017
  • Heating & Co... Master
  • 3,227 Answers
Hello Jean Thomson,
There are several reasons air-conditioning could go on & off frequently.
Thermostats can be set with close degree function...
Assuming your temperature variances are of no importance
the THERMOSTAT can be adjusted to be less sensitive...
BUT BY FAR... the most common reason for rapid cycling
of the A/C are air leaks and poor insulation...
Your local UTILITY provider will likely have FREE (or very reasonable) thermal analysis - evaluation programs... wit supported contractor services to improve your INSULATION and reduce ENERGY CONSUMPTION.
Also you might need to consider that your A/C system is simply poorly engineered to keep your home at a comfortable temperature...
Again... there are SPECIALISTS who are capable of analyzing your existing structure... and recommending appropriate systems sizing to economically operate efficiently....
Nothing here for the uninformed noviciate... all highly technical.
Save money... Get a PROFESSIONAL ANALYSIS..
Hope this helps!!
Carnac the Magnificent
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
Sep 30, 2012 | Honeywell Programmable Thermostat Heater
I have a Samsung side by side model # SRS 632NSS. it is about 18 months old. The freezer side does not function but the fridge side is normal .We have tried turning it off and resetting it however it is...
Defrost cycle is very often. Check freezer timer/thermostat might be cuts off frequently. Check thermostat setting..Check fridge is working continuously until frosting over freezer by keeping thermostat at 9' clock position. If not replace thermostat.
Jan 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
Very hot water then it kicks off and I have to frequently reset
Even though the water is very hot do you run out quickly? If so the problem is the 'dip tube' if not it is most likely the upper thermostat.
May 07, 2010 | RELIANCE ELECTRIC WATER HEATER
I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Jan 30, 2010 | Heating & Cooling
Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
My thermostat went from cut on & off frequently to not turning on at all but it it works if I have it set to heat and switch it from Auto to oN. Is thermostat broken, it's only 2 years old.
Remove the red and white wires from the R and W terminals on the thermostat. Cross them together and wait to see if your heat starts. If it does, trash the thermostat. If it does not, you have a furnace or wiring issue.
Dec 10, 2009 | Honeywell Electronic Programmable...
My heater won't turn on. It is the first time we tried to use it since I installed the thermostat a few months ago. My husband turned the mode to heat and the fan to on. However, only cold air is coming...
you need to bypass the thermostat wire it jumper wires. in other words jump the wires till the furnace comes on. there are 18 volts at the thermostst. listen for it to click. and set fan to [auto] always
Dec 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
