Question about RCA Televison & Video
I have a rca model led65g55r120q tv flickers and no sound
I left house for 2 hours and upon return had sound and no picture, turned off/on lost sound, disconnect power and reconnected, picture flashes and no sound, tv is 16 months old, how do i fix it
  • John mullen Jan 12, 2017
    Well, if you've already swapped a Tcon, and it's still doing the same thing and you already have the back open I would get a replacement main board. Might be the power supply(?) but if you examine the boards very closely you might see a scorch mark or other visible sign that the magic smoke escaped :) Usually a capacitor, one of the connectors or even a fuse/fuse-link would be a weak spot. But once you're past two boards and 4+ hours of work it's time to think replacement; if this were a Panasonic Viera or other plasma display it'd be worth the effort but a badge engineered LED TV is almost a throw-a-way. No real way to tell if this chassis suffered from poor design or materials but considering all of the replacement parts available...
  • RCA Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Jan 12, 2017
    Master:
  • 294 Answers
Check all cables for loose connection, try another input for picture (DVD, BLu-Ray, etc). If none of the other inputs work then it's a panel problem (display) If one or more of the others work then it's a problem with either the tuner or the signal.
Testimonial: "done that, hooked up another tv it is fine, i replaced tcom board and no change still led flashes every 10 seconds"
Have a panasonic plasma tv model #pc-p5052. lost picture and now the power light flashes. How do I reset the tv?
try disconnecting the power cord for a 2/3 minutes then reconnect if no good then the power supply has gone down
Dec 10, 2017 | Panasonic Televison & Video
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sharp aquos 65- we have sound but no picture. What do I do?
There has been a power supply failure. The process of disconnecting then reconnecting the TV shocked the failing power supply back to life but ultimately it failed
Jan 29, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Need to reset phone after power outage. CL keeps flashing - alternately flashes with CL and 0
Here is the procedures on how to reset the phone:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
Jul 15, 2011 | Uniden Cordless Phone
Hi - I have a HP Officejet Pro K5400 printer. That printer & my Dell Optiplex GX620 was left on during a 2 week office absence. When I returned the blue ink cartridge indicator light was blinking and...
Please follow the steps in the order below and check.
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
Now perform these steps on the computer...
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
now please print and check
May 20, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
We hooked up my laptop to our maxent plasma monitor/TV. It was working fine. I left for a short amount of time and when i returned, i lost picture. We have since discovered that we are able to get sound,...
u my have put the tv in shut down mode get your book that came with the tv and look for instrue on that tip always keep your plasms in the coolest spot in the room you wnnt them to stay cool heat stressess the gasses never hook up vides games to your tv also u only get about 3000 hrs before it needs expxnerxrepair hope this helps
Jul 25, 2009 | Televison & Video
My XSA 975 telephone was accidently disconnected from the power outlet. When reconnected I found cannot dial out but can receive calls inward. I have tried disconnecting the AC adaptor and reconnecting...
I unplugged the AC Adaptor from the wall socket and left unplugged for an hour or so (a few minutes as per the trouble shooting advice page in the instruction manual did not work). I then reconnected the adaptor to the power and the phone returned to normal service.
Dec 04, 2008 | Lands Phones
No picture
with most startup issue with this model there usually is a blink code sequence on power led on front of set. regardless of sequence though you would want to isolate problem by disconnecting y main from power supply and check voltages on power supply and if they come up replace the y main and y buffer boards located on left side of tv looking from back and if voltages do not come reconnect y main and disconnect x main and check voltages again and if still not coming up reconnect and verify vs on command on pin 2 of logic interconnect and if 3 volts present replace power supply and if 0 volts present replace ssb
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
803 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
