Question about Ovens
I have an nor oven.the glow plug lights then the gas comes on but goes off after 20seconds.there is also a grumbling noise at this time.is it the safety valve?
jumptrout51
  • 3361 Answers
SOURCE: Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Posted on Mar 26, 2009
  • 2187 Answers
SOURCE: Gas oven igniter glows, but oven does not turn on.
That is correct. You will have to check if the valve needs replacement or if there is power being sent to the solenoid for the valve. There must be just a connection problem.
Posted on Aug 17, 2009
protek480
  • 1714 Answers
SOURCE: glow plug comes on and smell gas but no fire
That is a bad gas valve. Need too change it out. The glow bar is working but the valve is not opening.
Posted on Sep 02, 2009
Testimonial: "With the information I gave, I give him thumbs up. I forgot to put in the top burners work fine."
mgprice
  • 744 Answers
SOURCE: no gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Posted on Oct 01, 2009
  • 949 Answers
SOURCE: The Glow Plug is glowing, but oven will not light up.
This may sound strange but it is most often the glow plug that is bad. What happens is as the ignitor (glow plug) ages the resistance internally rises, this rise gets to a point where it limits the electrical current just enough that the valve no longer opens.
Posted on May 05, 2010
Oven will not light sometimes
I HAD THE SAME TROUBLE THIS WEEK-I'VE GOT A KENMORE RANGE WITH ELECTRIC-GAS COMBO AS MOST ARE NOWADAYS. THE TECHNITION THAT CAME DOWN SAID 95% OF THE TIME IT'S THE GLOW BAR IGNITOR THAT GOES BAD.
EVEN IF IT GLOWS A LOT OF THE TIME ITS STILL BAD BECAUSE IT DOESN'T PUT OUT ENOUGH ENERGY TO OPEN THE SAFETY VALVE TO IGNITE THE GAS. THAT GLOW BAR IGNITOR CAN BE FIT WITH SEVERAL DIFFERENT ONES UNIVERSALLY BECAUSE IT CAN BE SPLICED INTO OLD WIRE PLUG AND USED . YOU CAN WATCH YOU TUBE VIDEOS AND DO IT YOURSELF IF COMFORTABLE DOING SO.
Jan 25, 2015 | Ovens
When you turn the temp knob the light will come on the panel but the oven will not light. Stove works fine. We have had this unit for 12 years. Thanks Bob.....
can you hear gas coming in when you turn the know to "ligth" if not the you may have either a bad gas valve or the safety feature has detected something wrong, and has shut the gas off to the oven. first determine if you do indeed have gas., how does the oven light, is it pilot lit, or does it have a glow plug, if its pilot lit, make sure the pilot is running. if its a glow plug, you should be able to see it glow when you turn the oven on, if its not glowing it has to be replaced (or maybe the wiring has gone bad). either way that's where to start.
Mar 19, 2011 | Ovens
Tappan oven tgfs26cba , oven does not light when turned on. control panel says it's working. glow plug glows hot. gas inot fed. was informed wife had taped oven vents to stop mice ??? could this have over...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 04, 2010 | Tappan Ovens
May 05, 2010 | Electrolux Ovens
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Glow plug comes on and smell gas but no fire
Sep 02, 2009 | Tappan 30IN ELEC IGNa Oven
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
