Question about Omega Juicers
My Omega 1000 juicer is new. It's assembled correctly but when I turn it on it only makes a soft sound and it will need juice. Thanks for helping.
sweetymommy
  • 4 Answers
SOURCE: wheatgrass juicing problems
Hi, I have an Omega juicer, and I've never had this happen. I recommend that you double check to see if you have the right parts attached. It comes with two inserts, one with a small metal screen on the bottom, the other has no screen, it is solid. The solid one is for crushing and proccessing food. The one with the screen is used for juicing. Make sure you have the correct one installed. If that is not the problem, I think perhaps the grass is too dry? Maybe there isn't enough moisture in it to extract much. I really can't say, though. Try juicing something else, like carrots, and see if you can get some juice there. If all else fails, contact Omega at their website. They have terrific customer service. I've tested it already with a warranty replacement.
Posted on Aug 06, 2007
SOURCE: how to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Posted on Apr 26, 2008
  • 356 Answers
SOURCE: Vibration
DIFFICULT TO USE. SHOULD HAVE GONE
FOR THE 4000 WHICH EJECTS THE PULP.
SOMETIMES THE BLADE JUMPS UP AND
CUTS THE BOTTOM OF THE CHUTE IN-
CREASING THE GAP BETWEEN THE BLADE
AND CHUTE BOTTOM. INSPECT AND I YOU
NEED A NEW COVER CALL OMEGA AT 717
561 1105.
Posted on Jun 30, 2009
  • 154 Answers
SOURCE: The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Posted on Jun 20, 2010
  • 356 Answers
SOURCE: My omega 1000 juicer won't
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
Posted on Apr 26, 2011
My omega 1000 juicer won't turn on - I just bought it today.
a call.
Apr 23, 2011 | Omega 1000 Juice Extractor
I have an Omega Juicer Model 1000. When I try to juice citrul fruit. The jicer may only turn for a second or two than stops. When I push down on the citrus it oftentimes will not operate.
If you're talking about the citrus attachment, there may be a
problem with the gearing inside. I have one for my Acme
which I don't use because of it's awkwardness and juice
splattering characteristics. Better off with an inexpensive
citrus juicer and leave the Omega to its carrots and apples.
Feb 08, 2011 | Omega 1000 Juice Extractor
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
My Omega 1000 goes off balance and makes a noise like it is going to blow up so I have to end of turning it off. It doesn't do this all the time but it is getting more frequent. This happens with any...
Yours and everyone else's. Best solution is to get a pulp ejecting type juicer.
I have a 21 year old Acme and know how to maintain and adjust it. Even
then I have vibration issues.
Sep 02, 2010 | Omega 1000 Juice Extractor
Juicer just stopped working
call or email omega url:omegajuicersdirect.com
Jun 29, 2010 | Omega 1000 Juice Extractor
My juicer spins off of its axis i think, wobbles all over, spinning itself in circles spewing juice everywhere
Omega and Acme juicers will vibrate because pulp
is not ejected during juicing. Only suggestion I can
offer is avoid soft produce and feed as slowly and
as evenly as possible. Been using an Acme for 21
years and did notice a duller worn blade does produce
less vibration.
May 23, 2010 | Omega 1000 Juice Extractor
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
the bottom to separate the base for better access
and view of the situation.
May 20, 2010 | Omega 1000 Juice Extractor
Heavy vibration and noise
YOU MAY HAVE CUT THE COVER CHUTE
INCREASING THE GAP BETWEEN THE
BLADE AND CHUTE BOTTOM ALLOWING
LARGER CHUNKS TO PASS THRU. INSPECT
AND IF NEEDED ORDER NEW ONE FROM
OMEGA AT 717 561 1105. ABOUT $15.
Dec 28, 2008 | Omega 1000 Juice Extractor
Vibration
561 1105.
Oct 01, 2008 | Omega 1000 Juice Extractor
Juicers Logo
215 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
