Question about Philips Audio Players & Recorders
How do I philips sa1ve04k/02
My mp3 is broken
How can i download a program to install my Philips GoGear SA2625/02 mp3 player
All support for the GoGear SA2625/02, is here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2625/02&slg=en&scy=GB
Use the quick start guide for connecting the player.
Quick start guide:
http://download.p4c.philips.com/files/s/sa2625_02/sa2625_02_qsg_eng.pdf
More information about this player in the manual.
Manual:
http://download.p4c.philips.com/files/s/sa2625_02/sa2625_02_dfu_eng.pdf
Need more help ? Just write a comment in this thread.
Apr 24, 2010 | Philips GoGear SA3020/37 MP3 Player
Philips 8gb Gogear SA3085/02 -"DRM License not available"appears
In your Windows media Player go into tools and select options. Select rip music and untick copy protect music. The music you have in WMP wont work. you will have to put them in again after you made the changes. Hope this helps
Nov 20, 2009 | Philips GOGEAR SA6045 MP3 Player
I need software to connect philips my mp3 player to my computer
You can get the software that you need from Philips website.
Enter your model #
Click on the link for your model #
Click on the Software & Drivers link
-Tha Mp3 Doctor
Feb 20, 2009 | Philips GoGear HDD1830 MP3 Player
Mp3 player model no. sa2640/02 display panel stuck on Philips
Get the latest software update from Philips website. I hope you live outside the United States because an SA2640/02 is not a US-compatible model - it was designed for overseas.
Jan 05, 2009 | Philips GOGEAR SA6045 MP3 Player
I haue philips mp3 sa3245/02
YOU CAN CONVERT PHOTO BY SMV CONVERTOR
Aug 28, 2008 | Philips SA3125\02 MP3 Player
My Philips SA5115/02 is realy broken
First, grab the Vista-compatible version of the software from Philips website
Then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 26, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips SA3125\02 MP3 Player playlist
Plug it in *Before* you start WMP. then open it, make the play list, select them all and right click and click "sync". if that doesn't work look at the help file.
Apr 12, 2008 | Philips SA3125\02 MP3 Player
SA2310/02
The SA2310/02 will only play .MP3 or .WMA music files.
It will not play DRM protected files, or .AAC files from i-tunes.
The SA2310/02 can store any other type of file, as a memory drive, but cannot read or play them.
Mar 21, 2008 | Philips SA2310 GoGear Mp3 Player
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
