Question about Winter Sports
I have a 1995 Bomdardier snowmobile 503 that starts every time with pull cord but will not start with electric start that was recently installed
  • 3,616 Answers
If it is battery and coil ignition it is possible the electric start is consuming so much current the voltage to the ignition system is falling and reducing the spark intensity. A larger battery or a capacitor discharge or other high-energy ignition system would be the answer.
An insufficient cranking speed is another possibility especially if the engine is 2-stroke, is 4-stroke with a performance cam, is old and worn or is magneto ignition.
  • 3 more comments
  • Vincent Greene
    Vincent Greene Jan 02, 2017
    I have a Goldwing battery It for winter use and there is weak spark when cranking by electric start but when it starts spark is great.My coil and ignition is an all in one package.Thank you for your comments
  • Vincent Greene
    Hi I also had a good battery charger connected and it was cranking quite fast but the spark was still a bit weak.Is there a diff in pick-up coils for an elect start compared to pull start
  • Vernon Taylor Jan 03, 2017
    So you are saying your ignition system is an energy transfer type using an ignition coil being driven by a winding in the flywheel magneto? Those are notorious for being merely adequate and rely on the points and condenser being in exceptionally good order. It is possible the wrong coil has been fitted at some time so that would be worth checking.
    Converting the ignition system to a ballast type coil and battery system would be feasible if the generator is good enough to keep the battery charged but a high energy system would be best.
  • Vincent Greene
    Vincent Greene Jan 03, 2017
    My system has a coil and ignition system combined in one unit. It does not have points --- it has pick-up coil and stator winding. The stator windings provide current for the ignition coil and module and charging system. When running there is plenty of spark on the plugs while cranking there is a much lesser amount.
    Ok. It is still an energy transfer system but brought up to date and not much more efficient than the old type but maintenance free. I have never tested the theory but I have read that a good pull on a starter cord produces a short burst of revolutions that exceeds a normal cranking speed - of course we talk about revolutions but it is piston speed that is important, consequently a short stroke engine must rotate at a faster speed than a long stroke engine for successful starting. Honda famously overcame the problem by using a clockwork starter on a couple of their models.
Snowmobile ran great all day but seemed to run different on the way home. The next day I went to start it and I couldn't pull the rope. I assumed it was locked up but not sure now.
Problem with starting next day [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-344777.html
Mar 25, 2013 - 13 posts - ‎7 authors
I have a buddy who couldn't start his CF1000 in the mornings and it was like you ... So is the recoil catching and you can't pull the rope? Recoil Rope stretched apart- showing Nylon cords
Mar 2, 2015
Engine seized then not seized??
Feb 23, 2015
2007 Ski-Doo Summit 800 X Motor Quit
Jan 31, 2012
My pull string went bye bye!!
Oct 31, 2008
More results from www.snowest.com
pull start not working - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/...snowmobiles/5470-pull-start-not-workin...
Jan 19, 2005 - When you pull the rope, it should have a little slack followed by a slight... and he couldn't believe that it didnt have a choke. does my sled not ... 1988 yamaha phazer- dies at full throttle
Mar 3, 2010
Need help uprighting snowmobile after tipping over
Dec 28, 2008
More results from www.snowmobileforum.com
Jan 04, 2016 | Garden
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
My sleds have sat for about a year and a half. I went to start and one of them I cant pull the pull start more than a quarter of the way
Remove spark plug, spray a little WD40 into cylinder, pull cord a couple times to blow out cylinder.
May 26, 2015 | Winter Sports
My 2004 arctic cat pantera starts with the pull cord but not with the electric start. Turn the key and no response whatsoever. Any suggestions?
check all wiring connections and a switch under the seat like lawnmowers have. there may be a cutout switch under the seat.
Feb 02, 2015 | Arctic Cat 2004 Pantera 550
We have a toro model 20031. The battery doesn't work and my husband disconnected all battery connections. Should the engine still start with the pull cord?
leave all the battery connections connected, then prime the carb, and pull to start, i have a quad with an electric start and a pull start, it will not start with the pull cord if the battery is not connected.
Dec 14, 2014 | Toro Garden
1995 pantera engine rolls over but wont'dwith electric startbut starts with pullcord
Make sure th battery is the right one for the machine,Someone probably cheaped out and put the wrong one in.
Mar 08, 2014 | Ski-Doo 2004 Summit Adrenaline 600 H.O
The pull cord on my jiffy ice auger model 30 has broke and I need a new one. I do not need a new ice aguer just the pull cord which is located at the top.
if you just need the cord -- most hardware stores do carry replacement cord ( sold by the foot ),, if you look in the chainsaw department you should be able to find the size that you need. as soon as you have the cord you can re spool the winding unit and this will restore the pull start function.
you can also buy the cord at your local lawn and garden shops,snowmobile shops or chainsaw shops.
if you have any further questions about this problem -- please feel free to ask,
c...
Jan 26, 2011 | Sport & Outdoor - Others
My pull cord on my polaris ind xlt broke can i put it back on
YOU WILL HAVE TO REMOVE YOUR RECOIL TO PUT A NEW PULL CORD IN. THIS IS DONE BY REMOVING THE EXHAUST THAN REMOVE YOUR RECOIL ASSEMBLY. BE SURE TO WIND THE RECOIL BEFORE INSTALLING YOUR NEW PULL GORD.
Dec 20, 2010 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
1,080 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
