Question about PRINTER Office Equipment & Supplies
There's no printer involvement. I just want to see my queue.
  • David Ellis Rhea Jan 02, 2017
    Hi charles thorne, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Q
How to remove need for printer queue
no need to remove the printer queue as it will select the next job automatically
so if you have set it printing something and the want to print another document , it will finish the first then start the second
the queue is need as it stops the printer printer printing any page from any where at any time so removing the queue will cause you lots of pain
Aug 30, 2017 | PRINTER Office Equipment & Supplies
How do I delete a print job?
turn off the printer and remove power to the printer. Job will be stored in printers memory. Go to p.c you printed from and check printer queue see if job is in printer queue on p.c as well and then delete from queue. If it does not delete from the queue go to if windows p.c the services under control panel and stop and restart the spooler service.if print job is stuck in the printer queue.
Mar 10, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Hi... this is really annoying... we have two computers in the office, one of them has XP and my laptop has Windows 7 (32-bit)... I was able to set up drivers for both our machines for our HP LASERJET 1000...
I had an issue like that some 6 months ago, and tried connecting several HP printers to my win7 PC.
The only thing that worked was to install the HP Universal print driver 5.0.1 (I believe that was the version) and then re-add the local printer as local.
The driver will ad another printer Icon called HP Universal printer, but ignore that.
You can also try downloading the latest UPD, from here:
Hope this helps.
Jun 14, 2011 | Office Equipment & Supplies
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
Sep 30, 2010 | HP Officejet 5510 All-In-One Thermal...
How to access print queue
You can find the print queue going to Start-Settings-Printer and Faxes, Open printer and faxes by clicking and You will find the printers installed. Select your printer probably the one which has tick mark on it ( default printer) double click to open and see the files in queue. You can delete the queue if printing stucked.
Other way to delete the printing queue if not getting deleted from the above method is to go to start-.>run type "services.msc"
search for print spooler service in the rights side pane, right click the service and stop it. Now again go to Start->run type
"spool" and hit enter. It will open up folder for you, double click on PRINTER folder and delete all the files in that folder. This will clear up the queue from printer. After deleting all files, go to again follow the same process to start the print spooler service. Go to start->run-> type "Services.msc" hit enter, on the right side pane search for printer spooler service, right click and start the service.
Hope this helps
May 19, 2010 | Microsoft Office Home and Student 2007...
Print Jobs remaining in printer memory indefinitely?
Take the printer back to her house, go to the printer controls, check the printer docs on cue (to see if there are any) and assure her that everything is OK. Tell her what happened, how it happened, and assure her that it cant happen again. This should put her at ease.
Mar 29, 2010 | Brother HL-2040 Laser Printer
Printer keeps printing page after page of meaningless symbols.
Did you have document in queue?If you have delete all documents in queue and restart the computer.Then restart printer.Wait to document in queue deleting.If you haven't documents in queue reinstall the drivers.First delete old, reset computer and install new.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Hp-ux print queue on a m305 mfp printer
Unplug the power cord for 10 seconds, or scroll through the menus for RESETS
Jan 05, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
Unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
Mar 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
23 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
