Question about Keurig Coffee Makers & Espresso Machines
I have Keurig 2.0. I have been cleaning it. I put white Vinegar in and running it through the maker. I am now running just water, but the water is not running any better. Suggestions?
    New Friend:
You need to clean the piercing needle of the k cup really well. Use a a safety pin to scrape the hole in the pin to get all the small coffee grounds out of the small hole in the piercing needle. I needed to do it 3 times. I scraped it then ran the coffee...each time a little more water came out along with some more grinds that were stuck. You would be surprised how much can get jammed up in that small space.
Posted on Sep 11, 2017
    New Friend:
  • 3 Answers
Did you clean the top of the Keurig. When the top goes down, it has like a needle point when may get clogged with coffee grounds. Get a paper click and make straight it object, I clean the paper clip the insert to point and clean out the excess coffee.
Posted on Jan 06, 2017
Keurig Elite B40 Coffee Maker water runs through when power turned on.
The problem is the water valve. The valve is either stuck open due to lime and scale build up or the valve has gone bad and needs to be replaced. The cheapest and easiest thing to do is clean it. Get a gallon of white vinegar and fill reservoir 3/4 of way with vinegar and rest with water. Make sure you put a big enough pot under it to retrieve the poor out. Run this through 2 to 3 times and if it is because of lime and scale this should clean it out and it should start to work again. Do this at least once a month but then you will only need to run it through once. Keurig does sale a solution just for this but white vinegar is cheaper and works just the same and will not hurt your unit. If this does not work then you need a new valve and in most cases it is cheaper to buy a new machine if you can not do it yourself. Hope this works for you and enjoy your coffee.
Nov 21, 2014 | Keurig Coffee Makers & Espresso Machines
How do i clean a keurig coffee maker?
Use white vinegar only. Do NOT use wine vinegar, flavored vinegar, balsamic vinegar, etc. Buy the cheapest one that you find in a supermarket. Fill the reservoir up halfway and run it through until empty. Then flush with plain water with TWO (2) full reservoirs of plain tap water.
Sep 18, 2014 | Keurig Coffee Makers & Espresso Machines
Recalls on keurig
Empty the reservoir of any water. Fill it back up with white vinegar. Get a paper clip and poke it up in to the needle that the water comes out of on the top of the lid. Run the vinegar through the machine until the reservoir is empty. You can even let the vinegar sit in the coffee maker for 10-15 minutes. Refill reservoir with purified water and run the maker until all the water is dispensed and the reservoir is empty. There should be no more vinegar smell. Never use tap water. Do this every two months. Note: if the area where the K-Cup sits gets dirty with grounds, put a large bowl under it and then pour a glass of water over the whole area to clean. Also, on occasion just run a cup of water through the machine (with no coffee) just to make sure that there are no grounds caught in the needle. Done!
Feb 19, 2012 | Keurig B60 Coffee Maker
The water comes out the top of the manuel filter so not all the hot water goes through the holder. the coffee is loosely put in the filter
Try running vinegar through the Keurig to clean and de-scale it. You should use white vinegar, run it through using several cups until there is no vinegar left, then use clean water to brew plain hot water until you can no longer smell vinegar. This will help de-scale the Keurig and potentially remove any plugged bits of coffee that may remain.
Mar 01, 2011 | Keurig Coffee Makers & Espresso Machines
Do I need water filters?
depending on how bad your water is..if you are on well water..you may want to filter your water..
Their is no filter, in the unit...But you will have to do a vinegar/water clean out...i put 1/2 cup white vinegar with full tank of water..keep running machine until empty, then run a full tank of clean water..
taste water..so no bad taste
Dec 18, 2010 | Keurig B70 Coffee Maker
My Keurig B70 has begun dispersing various amounts of water no matter what size cup is chosen
you will need to try the vinegar/water cleaning... 1/2 cup white vinegar to full tank water..run until empty..then redo, with clean tank of water....taste water when done, no bad taste
this has to be done on these machines at least once a year.....
How do I clean my B60 Keurig of scale
Empty the water...
start with half distilled water... half white vinegar...
just run it all day... take a break and let the vinegar work... it will be heated up in the main tank... then pushed out to all hoses and sensors etc.etc...
enpty the container... wash it out... fill it with filtered or distilled water and run that until you no longer taste/smell the vinegar...
consider buying a brita pitcher and use that water for your Keurig... I do... and my unit goes for a long long time before it needs a vinegar washing...
P.S. dont use C.L.R. :(
It tastes bad.
Apr 25, 2010 | Keurig B60 Coffee Maker
How to clean the Keurig coffee maker.
fill the reservoir with distilled white vinegar and leave the brewer on for 4 hours (leaving the auto off option OFF). after the 4 hours, run the entire vinegar filled reservoir through the machine.
refill with water and repeat twice. your machine is now cleaned and descaled.
Apr 05, 2010 | Keurig Elite B40 Coffee Maker
Descale???
Fill it with a mixture of 1/2 white vinegar and 1/2 water. Run it through. Run 2 or 3 loads of fresh water to rinse the vinegar out. The scale will come out with the vinegar and the first rinse.
Mar 18, 2010 | Keurig B60 Coffee Maker
B60.Coffee maker was working fine untill yesterday, now brews 1 cup and pump starts but does not pump and machine shuts off. Help me. Bill Cobb
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 09, 2009 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
71 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
