Question about Whirlpool Washing Machines
I replaced a lid switch on a whirlpool washer wtw4815ew1 & accidently slid the part to the locked position. Now flashes the lock button intermittently. I've tried to reset it 5 x's. What can I do?
  • Whirlpool Master
  • 4,503 Answers
What often works on a computer might work on your washer. Disconnect the machine from the power and leave it for a while, disconnect the new switch and then power up the machine. Disconnect from the power again and reset and reconnect the switch and then power up the machine again.
Hope it works for you, very sorry if it doesn't...
  • Crystal Pepper Jan 04, 2017
    I actually had to open up the part and reset it to unlocked...Works like a charm now. :) Thanks for taking the time to answer!!!
the dr
  • 447 Answers
SOURCE: control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Posted on Jan 01, 2008
  • 1122 Answers
SOURCE: how to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Posted on Apr 20, 2009
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
marka19
  • 1430 Answers
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Nov 26, 2010
richroth
  • 9472 Answers
SOURCE: whirpool cabrio wtw5500xw top load washer will not start lid light flashes then goes out and into flashing pause mode
You will need to replace the lid latch assembly. Here is the part to order.
Here is a video to show you how to replace the lid latch.
Posted on Nov 19, 2012
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Jul 10, 2017 | Whirlpool Washing Machines
Whirlpool cabrio washer, I try to start a load by pushing the start button, the lid lock clicks shut like normal but then the light starts blinking and the washer wont run.
If it's the lid locking light that's flashing, then the Lid Latch assembly needs to be replaced. It's latching, but the switch inside it isn't working and doesn't recognize that it's latched.
They have the part and a video on how to fix it at this parts company.
http://www.appliancepartspros.com/whirlpool-latch-w10404050-ap5263307.html
Oct 03, 2016 | Whirlpool Washing Machines
My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
if machine is over 8 months old id suspect rust in lock arm as cause
Jul 22, 2015 | Whirlpool Washing Machines
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer displaying du code with 3 quick beeps
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal De
