Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
LOOKING FOR INFORMATION ON FUEL LINE ROUTING CONNECTIONS. FROM FILTER TO PRIMER BULB, TO CARB CONNECTIONS AND THEN TO RETURN BACK TO FUEL TANK.
  • 155 Answers
Most trimmer fuel lines run from line in tank with pick up filter to bottom of carby then out of top of carby to inlet on primer usually the smaller tube then out of the longer tube on the primer and back to the tank.
Posted on Jul 25, 2009
Need to know fuel hose routes from fuel tank to carb
I will include routings for an on the carburetor purge bulb and a remote purge bulb.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Apr 29, 2011 | Mtd Garden
I HAVE A RYOBI VAC/BLOWER MODEL RGBV3100 THE FUEL LINES NEED REPLACING THEY ROTTED OFF NEED TO KNOW WHICH WAY TO ROUTE FROM PRIMER BUTTON TO CARB
Feb 18, 2011 | Ryobi Garden
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 04, 2010 | Craftsman Convertible 25cc. Gas Line...
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
McCulloch 3216 fuel primer and gas tubes routing?
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Nov 01, 2009 | McCulloch Garden
I am replacing the fuel tank assy and purge bulb (i.e. primer) on my Sears Craftsman model 358.798940. The original plastic tubing was old and brittle and broke apart while disassembling, so I could not...
The order of fuel travel should be:
Fuel filter to fuel hose to Carb's Fuel Supply nipple. (On the main body of the carb)
Primer Plate Nipple on carb to fuel hose to Suction Nipple on Primer Bulb. (It must pull fuel thru the carb, not push)
Pressure Nipple on Primer Bulb to fuel hose to Fuel Tank Return hose.
When correctly installed, the fuel will be PRESSED into the fuel tank via the return hose when primer is pressed in . . . and SUCTIONED out of the tank and into the Carburetor when primer in released.
Hope this helps,
Dolf-
Oct 16, 2009 | Garden
Trying to put new fuel lines in all around... bulb has two connections, tank and carb. carb has two connections, I imagine that the tank/filter line goes into the carb, carb then goes out to bulb, bulb...
Fuel routing:
Tank to carb (filter on free end in tank, replace annually)
Carb to primer (primer sucks fuel through carb)
Primer to tank (primer returns excess fuel to tank) HTH
Lou
Oct 11, 2009 | Poulan Garden
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
901 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
