Question about Sony Video Cameras
Hi to all ! i have just do a question but i want to ask another things ... my camcorder Sony CCD-TR805E in addition to the problem of the microphones as i hope to be able to resolve ...
The camcorder have another problem ... when i put the playback of the tape, in the first 5 minutes it's great sound and video ... but in 10 minutes of playbacking the sound begins to make a background noise, that continuing playback becomes strong enough to cover the original audio, but the video remains perfect. but when i record a video that problem doesn't happen is a problem of audio heads, or other?! ...
philipp
  • 217 Answers
SOURCE: Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Posted on Sep 14, 2007
philipp
  • 217 Answers
SOURCE: cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Posted on Sep 15, 2007
  • 19 Answers
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Posted on Dec 21, 2007
SOURCE: very grainy playback
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
  • 33 Answers
SOURCE: Problem with Playback and Record on camera
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Posted on Feb 21, 2008
Hi i have a sony ccd tr805e and i have a problem ... the built in mic does not work ... if i hear the audio with a hearphones connected to my camcorder i hear a noise as covering the audio ...
I used to be an Authorised Sony Camcorder repair agent before I retired and a capacitor kit was available (for service centres) to cure many problems including no sound from the microphone. It could be the internal mic itself.
Dec 28, 2016 | Sony Computers & Internet
Motor noise when I turn on loud enough to heard on microphone
Use an external directional microphone with a rubber shock mount. You can get them cheap on Ebay
Nov 12, 2013 | Sony Handycam CCD-TRV95 Hi-8 Analog...
How many mega pixels is the sony CCD-TRV228E HI8 CAMCORDER PAL NIGHTSHOT
It is 380K gross pixels / 230K effective pixels CCD. If you want to view the full specifications of the Sony CCD-TRV228E Hi-8 Analog Camcorder, you can go here.
Apr 07, 2011 | Sony CCD-TRV228E Camcorder
On my Sony Hi 8 Camcorder every time I try to record or play a tape,it does'n't play and only appears c:31:23
This error comes due to missing reel pulse of mechanism, remove battery/ power source from camcorder and tap gently top cover of camcorder with your palm few times, reattach battery and check playback.
Hope this will solve your problem.
Let me know if you have additional question.
Thanks.
Dec 12, 2010 | Sony Hi8 CCD-TRV138 Camcorder
How do I get the sony handycam dcr-hc30ntsc to show me a pictuer wale recording or any thing
If camcorder does not show live view in view finder and lcd screen but shows good picture in play back of old recorded tapes then ccd imager chip is defective in camcorder and need to be replaced.
It is not user level repair as soldering work is needed to replace ccd imager chip.
Thanks.
Oct 18, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
I have sony camcorder CCD-TRV138, record fine but without sound . I checked de camera and changed the microphone but nothing...
There is sound processor chip on main board that got bad and need to be replaced and it requires precise soldering work because it is SMD chip mounted on surface of board.
Let me know if you need part number of sound processor chip of CCD-TRV138
Thanks.
May 28, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Camcorder will not show picture records only
CANON relied on Sony to install their CCD (The image sensor) on most of their mini camera recorders. The mount for this CCD Component is defective. Canon recognizes this and currently, (2009) offers a 100% free replacement of this part.
The effect of the malfuctioning CCD is as you describe, everything works except there is no image captured.
I took mine in and they repaired it, no questions asked, except that I may want a few other things fixed up while they were there. I declined the additional work and it didn't cost me a cent.
Find Canons website and they have a deeler locator there where you can find an authorized repair center.
Dec 07, 2009 | Canon ZR100 Mini DV Digital Camcorder
I have a sony ccd-fx420 video camcorde. Destorte signal output
Its an old camcorder or 1995 or some thing and got leaky electrolytic capacitors problem on its main board that requires replacement. These capacitors are approx 60 to 70 and very difficult to unsold old and sold new capacitor on main board.
It does not worth to repair.
Thanks.
May 15, 2009 | Sony Video Cameras
I have a Sony Video8 Handycam CCD TRV211.
If you are asking about CCD-TRV211 camcorder?
CCD-TRV211 is analog Video-8 camcorder so its movie data is not digital and can not be connected directly with computer via USB port.
Best and easiest was is to connect camera with DVD Recorder and burn DVD, this will convert analog movie file into digital data and you can copy it to hard disk of computer.
Mar 31, 2009 | Sony Handycam CCD-TRV308 Camcorder
Sony handycam CCD-TRV128 Hi-8 camcorder
if your camera will play any previously recorded tapes , the microphone may have failed due to humidity - usually ; if your camcorder has an external mic input ? an external microphone - will confirm this ;
Jul 25, 2007 | Sony Handycam CCD-TRV128 Camcorder
Video Cameras Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
