Cell Phones Logo
S
Sonya Wade Posted on Jan 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant connect to Wi If .it says no wi if connection i try to set up internet conection but their no Wi If icon
Tony Curto
Level 2:
Sergeant:
  • Expert 246 Answers
  • Posted on Jan 02, 2017
Tony Curto
Expert
Level 2:
Sergeant:
Answers
246
Questions
Helped
49640
Points
675
Do you own a wifi connection. try connecting by pressing wps button on router/modem
My zte lever won't hook up to my home Internet.. Please help
This tutorial will explain how to get connected to Wi-Fi on your ZTE Tania Connecting your phone to a Wi-Fi network means you can access the internet, download apps and perform other tasks without incurring data charges.
This guide will show you how to get connected on the ZTE Tania.
How to connect to a Wi-Fi network
  1. From the main menu either swipe right-to-left on the touchscreen or press the right arrow button on the top right of the interface.
  2. Scroll through the menu and find the 'Settings' icon, then tap it.
  3. Press the button marked 'Wi-Fi'.
  4. Tap the Wi-Fi networking On/Off switch to turn Wi-Fi on.You'll then see a list of available wireless networks.
  5. Select the network you want to connect to.
  • If you selected an open network, your phone will automatically connect to the network. Note that some Wi-Fi networks, such as ones you might find in coffee shops, restaurants, or hotels, may require you to enter a password in your web browser before you can connect.
  • If you selected a secured network a password box will pop up. Enter the required password and then press 'Done'.
When you're connected to a wireless network, the wedge-shaped Wi-Fi connected icon appears in the status bar and shows you the signal strength - indicated by the number of bands that light up.
Unless you have wiped your phone, you won't be required to re-enter Wi-Fi details again as your handset should remember them.
How to connect to hidden networksA Wi-Fi network might be hidden, which means the network name isn't broadcasted. In this case, it won't appear in the list of available networks on the Wi-Fi Settings screen and a notification won't appear when the network is in range.
To connect to a hidden Wi-Fi network when it's in range, you'll need to enter the network name and password. Remember that the network name and password are case sensitive.
  4. Ensure that Wi-Fi is switched on.
  5. Press the 'Advanced' button.
  6. Tap the plus (+) icon.
  7. Enter the network name.
  8. Press the 'Add' button.
  9. On the 'Sign In' screen, enter the password, then tap 'Done'.
How to disconnect from a Wi-Fi network
  4. Tap the Wi-Fi Networking On/Off switch to turn Wi-Fi off and disconnect from the wireless network.
Alternatively, you can also press and hold the network name and then tap 'Delete' to disconnect.
However, bear in mind this removes the security settings if it's a secured network, meaning you'll need to enter them again next time you reconnect to that Wi-Fi network.
http://www.knowyourmobile.com/products/15952/guide-how-connect-wi-fi-zte-tania
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Cant conect me DS light to my Wi-Fi
http://www.nintendo.com/consumer/wfc/en_na/ds/wrInitialSetupHelp.jsp
If fail:
Make sure that the wifi settings you have are connect.
See if you are able to connect to another wifi connection.
-Make sure you know the wireless settings for the other wifi connection.
-You may also want to try to connect to an unsecured wifi.
2helpful
2answers
How do i get my phone to connect to the internet
You must have internet service, example an anything data plan. Then all you do is tap on the internet ball and it conects.
1helpful
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
3helpful
Can i connect my samusung jet to to my home hub? for free?
Hi Becky,
To connect your Samsung phone to your home wi-fi network, the basic is: 1. On your home screen, click on the bottom right "menu" button. 2. Got to the 1st screen , where the little gear icon for "settings" is at the bottom right corner. Open "Settings" 3. Click on "application settings" 4. Click on "Browser profiles" 5. At the bottom right you should see: "Search for wi-fi". Click on it. 6. It will now serch for your home wi-fi network. 7. Once it find your network, click on it and enter your security detail. 8. Now you network is listed as part of the Browser profiles. 9. Now you can select your wi-fe network as your default browser profile.
Now when you open the browser it will try to conect to your wifi to start browsing. If you use your home wifi internet to browse you will not incur cellphone/mobile phone network charges. When browsing based on your wifi network , you should see a "green" connection symbol at the top of your phone...
Enjoy :) Ed
1helpful
How do i connect my samsung jet to the internet through wi-fi
Hi, The basic is: 1. On your home screen, click on the bottom right "menu" button. 2. Got to the 1st screen , where the little gear icon for "settings" is at the bottom right corner. Open "Settings" 3. Click on "application settings" 4. Click on "Browser profiles" 5. At the bottom right you should see: "Search for wi-fi". Click on it. 6. It will now serch for your home wi-fi network. 7. Once it find your network, click on it and enter your security detail. 8. Now you network is listed as part of the Browser profiles. 9. Now you can select your wi-fe network as your default browser profile.
Enjoy :) Ed
4helpful
Samsung jet s8000
The basic is: 1. On your home screen, click on the bottom right "menu" button. 2. Got to the 1st screen , where the little gear icon for "settings" is at the bottom right corner. Open "Settings" 3. Click on "application settings" 4. Click on "Browser profiles" 5. At the bottom right you should see: "Search for wi-fi". Click on it. 6. It will now search for your home wi-fi network. 7. Once it find your network, click on it and enter your security details. 8. Now you network is listed as part of the Browser profiles. 9. Now you can select your wi-fe network as your default browser profile.
Enjoy :) Ed
2answers
I cant get internet on my ipod touch when i am conected to wi-fy
This error means you're not connected to an internet-enabled network. If you want to surf the internet, you'll need to connect to a wireless network; you do that by going into Settings, then Wi-Fi.
If the WiFi option is off, press it to turn it on and it'll scan for near by networks. Once you find one that is unprotected, or one to which you know the password, you can connect to it by pressing its name. Once you connect, if that network allows for internet access, you can surf.
If you don't have any wireless networks within range, you can always set one up yourself. You can do it either with a wireless router, which will give you a permanent access point you can use whenever you feel like, or using a laptop - but that's difficult, not permanent, and has a very short signal range (Though it's free if you already have a laptop with a wi-fi card).
My Ipod touch used to let me on anything on the internet but now, it says that the wifi is connected but i cant load anything on the internet. for example, when i try to get on youtube it says "you cannot...
Select "Settings" and then "Wi-Fi."  Verify that the Wi-Fi is switched to the "On" position.  Also, verify that you are not connected to a "closed" connection (indicated by a lock icon next to the connection icon).
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
