Question about GE Refrigerators
Where is the coils located on a GE refrigerator
  • GE Master
  • 5,323 Answers
DO U MEAN CONDENSOR COILS OR EVAPORATOR COIL?
where is the coils located on a GE refrigerator - 26423875-mnt2j1hw3gokxjshdcwwfxa2-3-0.jpg
where is the coils located on a GE refrigerator - 26423875-mnt2j1hw3gokxjshdcwwfxa2-3-5.jpgads/images/26423875-mnt2j1hw3gokxjshdcwwfxa2-3-5.jpg" alt="26423875-mnt2j1hwhere is the coils located on a GE refrigerator - 26423875-mnt2j1hw3gokxjshdcwwfxa2-3-9.jpg>
Posted on Jan 03, 2017
I would like to get a wiring diagram for GE refrigerator defrost system (GSS25SGRE SS)
replace defrost control board or timer and inside freezer the bimetal (located in at top and rigth of the evaporator coil, test the heat element conductivity with a voltimeter
Oct 02, 2014 | GE Refrigerators
WHY THE FREEZER FUNCTIONS BUT THE REFRIGERATOR SECTION DOES NOT FUNCTION ON A GE PROFILE BRITA FRIDGE?
Check for failed evaporator (cooling coil) fan motor, located in the freezer or a failed component in the automatic defrost system.
Sep 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Refridgerator side is set to 34 but temp reads 52 last night freezer was at 20 when set to 0 cleaned coil of dust now reads 0 but fridge side still wont come down it is a GE side by side
your evaporator coil in the freezer behind the rear panel is iced up and cold air cant flow thru ice,defrost the evaporator coil,then check continuity of the heater element under the coil,if its good,then suspect the defrost control,usually located in the refrige side on the upper area
Jul 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost controls
the defrost heater and termination thermostat are located on the freezer side at the evaporator coils behind the back panel. the control board is located at the rear of the refrigerator behind a metal panel.
May 28, 2010 | GE HSM25GFTSA Side by Side Refrigerator
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Defrost Heater on Refrigerator
It's located on the freezer side.Take off all the shelves and the drawer and you see a panel with lots of screws atached to the back wall , take it out and you'll see the coil and the heaters atached to it ,one in the bottom of the coil and the other in the middle.
Apr 17, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
GE side by side
check your main board (located on the back wall of the fridge). pull board out and check back of it, usually one relay legs burns out.
Oct 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
