Question about GE Refrigerators
Where is the coils located - GE Refrigerators
    Top Expert:
  • GE Master
  • 40,389 Answers
Look on the rear
Vehicle component location
There are 2 coils on an a/c unit. The condenser coil is located under the hood next to the radiator. The evaporator coil is inside the vehicle, usually under the dashboard with the heater coil.
May 20, 2013 | Toyota 4Runner Cars & Trucks
Where are the coils located on the engine of a 1988 Buick Regal?
As you are standing in front of the car, the coils and module should be under the exhaust manifold in front of you. You can follow the plug wires to find them. You may have to remove the cooling fan to gain access.
Aug 24, 2012 | 1988 Buick Regal
What is the plug wire diagram for a 2000 chevy lumina?
2000 Chevrolet Lumina 3.1 liter V-6 VIN "J"
Hope helps.
Mar 29, 2011 | Chevrolet Lumina Cars & Trucks
Can't find location of all six spark plugs
The plugs are located below the 6 ignition coils. The three front ignition coils are located underneath the plastic engine cover that has the V6 3000 marking on it. The other three coils are located in the same position, in the other engine head, towards the rear of the engine compartment. They don't have a cover over them. You will have to unbolt and unplug each ignition coils to remove it.
Nov 05, 2010 | 2000 Nissan Maxima
Where is the coil pack located on lincoln ls v8 7
Driver side valve cover
7mm socket to remove coil covers and coil
1 thru 4 pass side
5 thru 8 drivers side
Front to back
Jul 12, 2010 | 2002 Lincoln LS
Where are the ignition coils located?
Jun 07, 2010 | 1997 Nissan Pathfinder
Where are the spark plugs located/
This car uses coil over plug system,the sparkplugs are located under the coils, each cylinder has its own coil, remove one coil at a time,remove the bolts holding coil,disconnect connector and pull coil up,take note ,there a spacer under the coil where the bolts go, make sure not to loose them when removing coil or bolts,after you remove coil then inside the hole is the sparkplug, do this with all cylinders, hope this helps.
May 30, 2010 | 2002 Chrysler Concorde
Need location of pick up coil on engine please
PICK UP COIL FOR WHEEL CYLINDERS? ENGINE coil? ALLECAROMETER PICKPUP coil or master brake cylinder pickup coil for anti skid brakes? or RPM pickup coil for tach and speedo?
Apr 11, 2010 | 1999 Oldsmobile Bravada
Where is the coil valve located?
The coils on this unit are located on the gas/burner valve Assembly. this is a all in one situation. everything is located on the gas valve assembly. you will need to remove the coils from the gas valve assembly.they are attached to the valve assembly.
Located on the back side of the unit on the lower back side. (right)
May 25, 2009 | Whirlpool GGQ8831L Gas Dryer
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
