Question about Sewing Machines
Can I still use my machine if the knee leaver is broke
  • Sewing Machines Expert
  • 483 Answers
I would think so, I certainly can on my Pfaff machine. I assume you mean the knee lift
Can I use a knee lift with my Janome DXL603
In the Specifications section, this indicates a knee lift is not available:
Janome DXL 603 sewing machine computerised 60 pre programmed stitches...
For a knee lift, there would need to be an access hole at the lower right front to install a knee lift. Looks like there is not one on this machine.
Mar 01, 2017 | Janome Sewing Machines
My Pfaff 2140 feed dog is not working. I can manually raise and lower it using the leaver near the bobbin. The leaver on the outside of the machine under the screen no longer works.
One of the control arms inside the machine is broken or has lost its mechanical connection. These are very complicated machines, well worth the repair costs. Have a authorized repair shop technician make the repair.
Cheers,
Embroidery Services
San Diego, CA
Jul 09, 2016 | PfaFF Sewing Machines
How do I tilt my machine back to access the oil pan? The knee lifter bar is in the way and hit when I try to tilt my machine.
I don't know if you were the person that I was just writing to or not. I didn't think about the knee lift. I generally sew on a Juki DDL-5800 and we don't have the knee lift problem. I have an older walking foot with the knee lift. You might try what works with that one. Grab the front of the knee lift, push it towards the back and at the same time pull it up and left. There is a metal peg at the back of the shaft that will release and let you pull the knee lift out so that you can push the machine back. If that doesn't work, see if you can contact me and I can call someone else to find out.
Shirley :)
Mar 20, 2016 | Juki DNU-1541S Industrial Walking Foot...
How can I fix the knee lift that is very hard to push
how much srping tension do u have on presser ft. is the tension knob on top of machine screwed all the way down., never necessary by the way. next your arm attached to the knee lifter may be bent and not contacting the lifter bar for presser ft. get under machine and move knee lift with hand to see where contact is being made. bend accordingly. also the link from knee lift bar to link inside the back of the machine may be broken. u have to take off the back panel with all its screws. watch the gasket. you can replace the bar yourself since this will not intefer with the machine timing etc.
Jun 13, 2014 | Juki Sewing Machines
How to connect knee lifter Consew 206 rb-5. Knee lifter got disconnected
Consew 206RB-5 knee lifter installation with measurements and pictures: http://indsew.com/tips_and_guides.asp - There is a picture of how to put it together and there is a blue print with measurements how to position it and install it.
May 11, 2014 | Consew 206RB
Elna 600 manual
I'm not sure about your machine but I've used an Elna that had a leaver for stitch length and when you pushed the leaver up all the way it would activate reverse stitching.
Apr 22, 2013 | Elna Sewing Machines
Automatic button hole not working in ambition 1.5
it sounds like the machine needs some adjustment in the buttonhole
gears or the cam could be damaged.
Jan 04, 2013 | Sewing Machines
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
Should there be a pedal with this machine (201K) purchased in 1953? What is the metal twisted bar for?
sounds like you have a cabinet model, yes this machine requires either a foot or knee control, the twisted metal is probably part of the knee control mechanism. order foot contrrol or knee control to fit the machine from linssewvac@hotmail.com
Sep 25, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
