My LRZ400 appears to have no power at the control panel.
I have 26 v from the transformer to the circuit board. How do I determine if it is the control panel or the circuit board?
the dr
  • 447 Answers
SOURCE: Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
Posted on Oct 27, 2008
  • 9098 Answers
SOURCE: Whirlpool microwave/oven combo- model #RM288PXS
That would be a problem with your control board. It probably needs a few capacitors and a relay replaced and minor circuit board repair.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
P.S. (to Guest: Please make a new post with your model number. I think your problem is different.)
Posted on Nov 08, 2008
  • 86 Answers
SOURCE: GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Posted on Jan 02, 2009
SOURCE: Maxent 26" lcd tv, shorted circuit board
the best and easiest way to track down a short is with a digital multimeter just check for continuity throughout the circuits.If you you cannot get your hands on a multimeter use a compass.It will detect and move left to right when there is a complete circuit and as soon as you hit the short the needle will be dead still. Fix the short and test.It would probably be alot cheaper than trying to track down a part with no certainty of it.Hope this helps
Posted on Mar 18, 2009
  • 8220 Answers
SOURCE: GE refrigerators GSS23WSTASS: The control panel on
GSS service manual
Posted on May 13, 2010
I have a Samsung LED TV model 65h6203afxza,version mh01 with a darkened rectangular screen area at the top(left to right)which extends about 10 inches down from the top.
Samsung TVs have three boards, ie, video card (center), input (control) where a single button control/inferead and HDMI s are connected and a power board where 120 volt is plugged in. A chip checks all the circuits before powering up the TV. Usually, fail in the high voltage circuit will cause many issues.Check the high voltage for at least 390 volts at the capacitor after the tiny high voltage transformer, as the power board supply all the other circuits, ie the backlights.
Dec 27, 2017 | Samsung Televison & Video
I purchased a home a little more than a month ago that has an Aqualink RS8 system installed. A couple weeks ago, we noticed that in the indoor control panel was not lit, so we checked the outside panel. ...
open the aqualink control box remove the top panel see if the 4 pin red connector is plugged in and tight if it is check to see if the one inside is connected if ok check to see if wiring is cut
Sep 27, 2014 | Jandy Aqualink All Button RS Control...
No power
you have a low amp fuse protecting transformer. could be thermostat issues.
Dec 12, 2013 | Ruud Rheem Corsaire Control Circuit Board...
Hot tub won't come on
Start at the spa.
  • Do you have voltage coming to the terminal strip in the control box?
  • Is it the correct voltage?
  • Do you have voltage at any point after that?
  • Is there power coming out of the transformer?
these are the starting points to determine if you have a bad circuit board or a bad transformer.
US Parts Center
Mar 27, 2013 | Jacuzzi Home
I have a Jandy Aqualink RS system. The wires for one of the valve activators was shorted and the outdoor control panel and the indoor control panel lost power. None of the circuit breakers was tripped.
On the RS system there is a small fuse on the back of the circuit board. That may have been burnt. It acts as a safety for the transformer. Make sure ALL of the power is off, then check that fuse. Do not keep the shorted valve actuator plugged in. Replace it, or leave it disconnected. Then replace the fuse. Then re-apply power to the unit. Otherwise your transformer may go out next. If the fuse is not burnt, which would surprise me, you may have a burnt transformer.
I just bought an old spa from someone and the control panel is not turning on. It was rebuilt a while back and according to the original owner it was working, and when I drained it it appeared it was being...
If you are SURE there is correct power up to the spa pack you need to check to see that the topside control is plugged into the board.
if it is plugged in, it is either the 24volt transformer supplying the topside control, or the topside control is failed.
Did you hook up the hot tub?
Most common cause of topside complete failure is connecting to an improper power supply. This will immediately fry the transformer, and also maybe the topside control. It you are luck there would be a small 2 amp fuse next to the transformer.
If the whole board is without power, but you know power is going into it, it could be the main 50 amp fuse, which is usually white and about 1.25" long
Oct 28, 2010 | Pool & Spa
No audio novideo
This is a complex problem and should be returned for service at the service center. For customer service call this number1-877-467-4289. The problem could be one of many, such as a power supply board failure, or control board failure. It also could be cause by a failure in the power inverter circuit of bad back lights. This is why you should take it in for a service check. Hope this help you with your problem.
Apr 12, 2009 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
Top Televison & Video Experts
