Best Buy rep said it was because signal was below 720 HD. Box on Magic Sing says 720 HD quality. Solution, he plugged Magic Sing to new Sony Receiver. Video came up on TV. So new technology not backward compatible with Magic Sing?
SOURCE: No picture when on TV/Sat mode on receiver
Dear Customer,
Try another tv to this bales,
than try another cables with this your tv ,this way you got problem & find out solution on which you can spend time for ,
than try some channels to sets up your tv configuration,
or must not be imported from another country cause its not similar to your country's signal identification,
THNX
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
SOURCE: 720 and 1080 resolution
A firmware update needs to be done on your HD DVR
How to check firmware of your DVR? Check the link below
http://tacp.toshiba.com/tacpassets-images/notices/hddvd-checkingfirmware.asp
You can download the FW on the manufacturer's website
SOURCE: magic sing....i cant hear my voice or anything but all videos and songs are fine help!
you need to replace the voice coil. it is already grounded, that is the one inside the mic ball (where you speak or sing). it is not repairable so you need to purchase a new voice coil
SOURCE: N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
