Your answer says key is flashing but nothing is flashing on my screen.
How do i reboot dell Inspiron 660 with hotkeys
This is nothing to do with reboot keys, but the answer is CTRL+ALT+DEL
Your system has a Windows file corruption error and is not booting properly, the causes can be many so someone needs to look at it to try and fix it but it might require a re-install of Windows. Back up any precious files before a reinstall or you will lose them with a new install of Windows.
Good Luck
Dallas PC Doctors
Helpouts by Google PC Doctors PC MAC Repairs and Computer Services Just...
Aug 18, 2014 | Computers & Internet
4ways come on and security key light flashes as well as brake light flashes when using turn signals
Hi Anonymous, try the websites below they may help your issue:
Good luck and have a nice day.
Apr 16, 2014 | 2011 Harley Davidson FXDWG Dyna Wide Glide
Compaq Presario CQ61 will not start. Have removed battery and tried to start with just power cord. Nothing happens. If battery is installed the led with the lighting bolt will flash but laptop still will...
nothing happens, I will take that as no text shows on the screen
at boot (power button on ) time as it did for
CQ61 is not the full model number making accurate answers x10 harder. for any helper, who knows HP gear.
forget that huge battery, no laptop needs it to run on AC power.
most batteries this old are bad. same with the RCT/CMOS coin cell in side. page 55 shows how to replace IT.
The big battery is ALWAYS fix last DEAL. ok?
the blacks screens are 1st always, to diagnose them first.
ill pretend you said CQ61-100 (not 200,300. and so on)
looks like it was made in 2009 .
for 8 long years , you pushed power and saw
"Press the ESC key for Startup Menu" text,
but today, you see 'NOTHING" (nothing is nothing)
does the fan inside blow air and heard ? if not the AC pack is bad.
(wall AC >>>>Pack>>>>19vdc-to-PC)
so that is the black screen of deathh(sic) I call it.
so if the power pack is still good, we do the flash light test.
ever heard of CCFL back lamps, they ended in 2010
(see why my wanting real model numbers matter?)
if it has ccfl lamps they all fail about NOW.
the black screens of ***** list is here. and tests.
it has many causes. the ABOVE OR top CAUSES. ONLY
THE GOAL IS BIOS SCREENS. "esc" key BIOS is first
the cause of those are . here, 14 steps
remove power pack, and AC pack
push power button, for 10 to 30 seconds this is the HP
magic RESET, (its harmless)
AC PACK back in place. and to wall power hot.(means live power)
NEXT , if the fan works.!
if the fan does not work (say so please) and we can work that FIRST.!!! (in truth fan is first, it must blow )
ever clean out 9 years of lint inside? service it?
most CCFL were in fact inside Old C61 PCs.
see this? (this os folks changing them over and over)
They ended these junky CCFL in 2010, phase out.
a key year to not buy PCs older that that Laptops.
Nov 27, 2017 | HP Compaq Presario C500t Notebook
Answering phone
your mobile should be just flashed.cheers
Jan 13, 2014 | Motorola Mobility Defy Cell Phone
Hp Pavilion DV-4000 Screen
Are you saying the lcd screen is black? It seems like it booted up but nothing appears on the screen?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 03, 2012 | HP Pavilion dv4000 Notebook
My screen is white with nothing else on it
Take the backup for your phone and then just simply reset it to the default factory settings. you can do this by going through the settings of your mobile phone handset or in your case nothing is visible on the screen so just press "GREEN+POWER KEY+ * KEY" to format your phone.. Your problem might be solved for free..!!!
But if you are not that lucky, then there is only one solution, get your screen display replaced with a new one.
Apr 06, 2011 | Nokia Classic 2700 Cell Phone
Black screen with flashing curser, pressed f8 and R keys. nothing happening. have run a bios check they say nothing wrong been on black screen for 24 hours now. please help!!!
That screen is what happens when the BIOS can load Windows because it was severly corrupted, There's only one thing you can do - reinstall.
Oct 18, 2010 | Dell Inspiron 1545 Notebook
Right off the bat when I power up my HP Intel Pentum 4 3.2 mhz processor (with Hyper Threading and XP OS SP3 and the LCD monitor and an Intel Graphics Media Accelerator 900 with up to 128MB shared...
Reboot the machine and when you see the HP flash screen, tap the key that gets you into the setup or BIOS screen. This could be F2 or the escape key, just watch for it. Once you get into the BIOS pages, go to the last page and look for the text "Reset Default Settings" or something to that effect. Click to reset defaults and answer yes if it asks if you are sure, then tap on the F10 key and click yes to exit and reboot. Restart Windows normally.....if there is still a problem, reboot and tap the F8 key when you see the HP screen. Choose "Safe Mode with Networking", this will load safe mode and minimal settings and drivers but will give you internet access to get help for resetting safe mode through the control panel.
Jun 18, 2010 | HP Pavilion a450n PC Desktop
Motorola v635 dead
you have a software problem. take your phone for flashing. but if there was water damage, then the phone might be dead.
flashing the phone replaces the phone's firmware with new firmware, making the phone brand new
Jun 13, 2008 | Motorola Mobility V635 Cellular Phone
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
