HUD61 Ultima Cooker Noisy Fan initially when first turned on
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
What would happen if fan is disconnected noisy and not wanted?
NO NEVER EVER DISCONNECT FANS OR ANYTHING ELSE ON YOUR COOKER.
Your cooker may have at least two fans, one for heating the oven cavity and one for cooling the electrics etc inside the oven. If the fan is noisy, check to see the fan has not come loose on the motor (maybe left had thread) if the fan is ok, then the fan motor may need replacing!
Oct 20, 2014 | Ovens
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
My marshall mghdfx head fan makes noise when you first turn it on. what is this?
Some cooling fans are "throttled" depending on the sensed temp... these CAN be noisy upon initial startup.
It can also be bearings going out... best plan is to watch it and see if it gets worse.
Changing a fan is fairly easy. You have to observe the polarity of the connections. Replace with identical unit.
May 09, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Oct 25, 2008 | Hotpoint Ultima WF865 Front Load Washer
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Apr 12, 2008 | Belling XOU492 Electric Double Oven
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
