Question about Dryers
How do i wire my cuhn-75a-1 to use the "fan on" option?
2 Suggested Answers
  • 3284 Answers
SOURCE: MY ADP GARAGE HEATER MODEL CUHN-75A-1 FLASHES CODE
dirty flame sensor try cleaning it or there is air in the line
Posted on Jan 02, 2010
Testimonial: "Thank you very much, my heater is working again."
Lennox 80MGF2-75A-2. furnace wasn't working so we figured that the high limit switch problem and replaced it today. Exhaust fan wasn't working but other blower was. Now Exhaust fan on but other not.
The stack blower and circulating fan can whirl away merrily without so much as a hint of burner ignition. I don't know what the LED is supposed to be indicating. You may have a defective flame sensor.
Feb 16, 2018 | Heating & Cooling
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
I HAVE A BRAND NEW LF24-75A HEATER WITH LP KIT INSTALLED AND WHEN WENT TO START UP UNIT THE LAST BURNER IS ROLLING OUT WHITCH IS CAUSING NOT TO SENSE A FLAME. WHAT WOULD CAUSE THAT?
roll out from a burner chamber would be caused by a blockage or crack. the crack would only roll out when the heated air fan comes on. and then 1 more thing.if they forgot to install the orifice you could be dumping to much gas into that chamber
Feb 07, 2011 | Heating & Cooling
I am looking for a user manual for an ADP gas garage heater Model # CUHN-45A-4. Where can I find this and print it off?
http://www.adpnow.com/wp-content/uploads/2011/04/Troubleshooting-Guide-Unit-Heaters.pdf
http://www.adpnow.com/wp-content/uploads/2011/04/PS-UHPX-02.pdf
Oct 21, 2010 | Star Enerco Heat HSU45 Garage Heater 45000...
Battery light w/ power loss
how can it be that your battery and alternator are good but u still loose power??? then u'll have to check
1) your battery
a) turn your car off then check if your battery keeps regular Voltage should be around 14
b) turn your car on including all LIGHTS and FANS and see if its still 14 if its not 14 and going down then you have a power loss in your battery and your battery doesnt provide enought charge to Alternator
2) Alternator
For your car its OK to use battery with 75A if you put lets say 100A then you'll simply kill your altenators brushes
Jan 29, 2010 | 1998 Dodge Caravan
Need a power fuse 5x20mm 75A/250V
Radio shack they will have it or will order it !! Also check on line @ Wallco Industrial Electronics search for this item !! They have it also !1 swampratt200!!AAAEEE!!!
Jul 21, 2009 | Audio Players & Recorders
Dryers Logo
24 people viewed this question
Top Dryers Experts
