Question about Kyocera Cell Phones
My kyocera flip phone won't ring. It will vibrate but the ringer doesn't work. I could see that someone's calling, but it won't ring. Can you tell me how to fix the ringer?
    Sergeant:
  • 246 Answers
Raise the volume of ringer or go to settings and allow ring and vibrate
My setting for ringer is turned on, but my phone doesn't ring when someone calls me???
It could be that your selected ringtone is inaudible. Go into your settings and test the selected ringtone for calls. If you can't hear it, try another. Also check your ringer volume setting. It may be all the way down.
Nov 16, 2012 | Apple iPhone4 4G iPhone 4
Cleared caches but now nexus won't ring
mY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Jul 29, 2012 | Samsung galaxy nexus
The phone won't ring. How do I make it ring? I have gone to settings, sounds, ringer and alerts. When I click on that, the phone makes a ringing sound, but when calls come in, it is silent. Please...
Have you checked the switch on the top left of the phone?
That's the mute switch. Flip it in the Up position and that should fix your problem
If the phones ringing when you test the ringer in the settings, the ringer works. It's probably just muted..
I hope that helps...
Thank you
Aug 25, 2011 | Apple iPhone Smartphone
My phone doesn't ring or vibrate also the speaker doesn't work
Hi,there are three things you need to check..
The vibration..
The ringer...
The flex....
Hi, what makes nothing happens even when trying different levels of the vibration is because the ******** of the phone that makes the phone vibrate when someone calls is damaged.
You need to replace the ******** before it will respond again. It is located inside the phone,always round in nature.
When replacing the ******** of the phone,you have to be careful when unscrewing the phone screws.
Get a phone screw, unscrew necessary screw off, take the back cover off locate the ********, (round like the ringer)But the difference is clear.Go to any phone repair store around your area and purchase another phone by tell them the model and make of the phone.
After replacing the ********, screw back the screws and your done.
Would advice, if no knowledge about phone repairs, please contact a skill full personnel for help.
What causes phones not to ring out is when the ringer that makes you hear a tone when someone calls is damaged and does not work properly again.
The ringer is located inside the phone.You can get access into the phone by unscrewing the phone with a phone screw. It a little bit technical when unscrewing the phone.Just be careful not to damage the phone.
How to unscrew the phone.
Remove the back cover of the phone where the battery is,
then remove also the battery, at the edge you will see where the screw are located.(look closely).
After unscrewing,the screws, Open from the size of the phone,you will see where the ringer is located. It's usually round in nature. Remove and cover up the phone. (you can get a replacement ringer from any phone repair and sale of part store around you.
Ones your through with the ringer , 'wa la' Your done..
Note:if you can't loose the phone, in other not to cause damage to the phone,please contact a skill full personnel for assistance.Thanks.
Before you replace it,you can also clean up the ringer ,there might be dirt stopping it from working properly.
Hope it helped......
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and also the ringer and vibration...
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Jun 16, 2011 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Ringer....
SOUNDS LIKE YOUR SPEACKER GHAS GONE AND ITS CHEEPER TO BUY A NEW PHONE THAN TO GET IT REPAIRED
Apr 11, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
117 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
