Where to add the fabric softener - Washing Machines
    Sergeant:
  • 448 Answers
Same place as soup there is area in soap tray for softner
Htwp1200doww where does fabric softner go
You have to do it manually. Ugh. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
1. Turn OPTIONS knob to FABRIC SOFTENER
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Oct 04, 2012 | Hotpoint Washing Machines
G155
You have to do it manually. See below from manual:
Sep 09, 2012 | Hotpoint Washing Machines
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
My Bosch washing machine doesn't add the softener from its compartment
The first thing you should do is check the compartment from the fabric softener. If something is blocking the exit of the softener, the machine will not add it.
If you checked the exit or the holes in the valve of the fabric softener compartment and nothing seems to be stuck there, there could be a problem with your washer's timer. Check the timer and get a replacement for it.
source: http://www.washingmachineadvisor.com
Jul 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
The fabric softener is clogged with dried up fabric softener on my Whirpool Washer. How can I get it cleaned out?
You really cant take them apart without breaking the dispensers. Fabric softner is basically wax and fragrance. Add very hot water to the dispenser to melt the fabric softner. In the future, water down the fabric softner.
Feb 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
When should u add softener?
Dear seymour,
please rate this solution if it meets ur need else choose fixya.
Fabric softener is one of those things we don’t think much about, but use frequently. How does it work? How is it used? Fabric softener is essentially a chemical cocktail that helps soften the fibers in textiles. It makes them feel less harsh and has anti-soiling and anti-staining properties. With such names as Diethylenetriamine, Aminoethylethanolamine and Triethylenetetramine, these chemicals sound like something out of a science-fiction movie, but they are mostly byproducts of animal fats. Fabric softeners come in two types: liquids and dryer sheets. The liquid softeners are added to the rinse water for each load of clothes. Dryer sheets are paper or sponge-like pieces that are coated with the dry softener and are added to the dryer for every load. Some liquid softeners tout that they will leave clothes brighter and prevent discoloration from chlorine. These claims must, of course, be evaluated by each person.
Fabric softeners are used in any form to help make clothing feel softer and to prevent static cling. Anyone who has unloaded a batch of towels from the dryer in winter knows exactly what static cling is. Dryer sheets lubricate the textile fibers to reduce static electricity generated by the drying process. Liquid softeners serve much the same purpose.
There is a great amount of information about fabric softeners on the Internet, and while browsing, a person will undoubtedly come up on Web sites saying the chemicals in fabric softeners are dangerous and can cause a whole host of illnesses and allergies. There is no doubt that some people are allergic to the chemicals and/or dyes in fabric softener. They can cause rashes or upper respiratory distress. Some manufacturers have started producing dye and fragrance-free liquid fabric softeners in response to this problem. Some small companies also produce a vegetable-based, dye and fragrance-free softener that is biodegradable and less likely to cause allergic reactions. There are also some ways of softening the laundry without using any kind of commercial fabric softener. Vinegar and baking soda soften the fibers naturally. A person can add one-fourth cup baking soda to the load at the beginning of the wash cycle, and then a half-cup of white vinegar during the rinse cycle. Another home recipe suggests diluting 1 cup of glycerin in a gallon of water and using one-half cup of the mixture per load of laundry. Still another method uses three parts water to one part commercial hair conditioner. Fabric softener should only be used with standard fabrics. Fine washables such as linen or silk should not have any kind of fabric softeners used on them, if they are machine washable. The chemicals can destroy the look and feel of a fabric like linen, and dull colors in silk. However, most standard cotton and polyester blends are safe with the use of fabric softener. Dryer sheets are a blessing for socks and towels, since these items seem to be most susceptible to static cling. Liquid fabric softener can also usually be diluted to one-fourth strength in order make it last. There is usually no discernible loss of softness or increase in static cling when the softener is diluted. Each person needs to decide whether using a commercial fabric softener is appropriate. Those with allergies or very sensitive skin may want to consider a home recipe, since they are made of ingredients that are readily available. People also need to remember to keep the fabric softener from their fine or delicate washables, especially linen and silk.
Dec 17, 2008 | Admiral AW22 Top Load Washer
Remove the fabric softener compartment for cleaning
open up and on the left side toward the back you see a little tab push it down pull out the dispencer
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
