Question about Royal Office Equipment & Supplies
My Royal Crosscut Paper Shredder, Model # PCUA:16326H-FE will not turn on. Is there something that I can do?
  • Royal Master
  • 3,797 Answers
Paper shredders have a main switch and a couple of safety switches, the first of these is the one buried in the slot so the cutters are only moving when sheet paper is inserted and this switch has a very light return spring and flimsy linkage that easily jammed with paper scraps or easily displaced or sometimes it gets broken. The other switch prevents operation unless the unit is standing squarely on a container. Now my shredder is a few years old the unit has to be repositioned a couple of times before the latter switch engages.
The units benefit from being taken apart periodically and the buildup of dust and paper sraps cleaned out and maybe a brief spray of a dry lubricant around the moving parts.
2 Suggested Answers
  • 1218 Answers
SOURCE: NEED TO REPLACE MOTOR. SHAFT SLIPS ON GEAR. GEAR
For parts give Royal a call at 1-800-524-0799.
Posted on Aug 22, 2010
How do I remove paper stuck in my shredder????I have a Royal 10X Cut Paper Shredder. On label it has PCUA:29054E 10x 00324040. How do I take it apart to remove the wedged paper???
You may have to turn it upside down and go to work with tweezers and a utility knife to remove every bit of paper from the mechanism. I have found that 10X rating to be overly optimistic; the equivalent Royal shredder I am using currently groans and complains if more than a few sheets are fed in at a time.
Feb 22, 2015 | Royal Office Equipment & Supplies
How do I oil my royal crosscut shredder 1610X
To oil your shredder, squirt some shredder oil onto a piece of paper (don't completely soak the paper) that you wish to shred & feed this paper through your shredder.
Feb 10, 2011 | Royal VF1000MX Shredder
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
Lost Manual for Shredder
Not on-line that I know of but give them a call at 1-800-524-0799 maybe they can fax or e-mail something to you.
Jan 01, 2010 | Royal VF1012mx Shredder
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Aug 02, 2009 | Royal VF1012mx Shredder
29 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
