Question about Samsung Washing Machines
Samsung washer model wf42h5000a not draining correctly. 5e comes up. How do I fix it
  • Samsung Expert
  • 448 Answers
Clean drain pump maybe clogged or change pump
We have moved house and plumbed in our machine and code 5E has come up Any ideas what is going wrong and how to fix it
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error. You can perform following steps to resolve the issue : Clean the debris filter.
Jul 13, 2017 | Samsung Washing Machines
My top loader washing machine shows SE. Please assist.
I has the same 5E mistake with my Samsung washing mashine.
5E looks like SE on the screen, but it is 5E.
This is what the manual says:
5E - Your washer is not draining. It can
also mean that the unit senses a
small clog while draining
Do the following:
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
Apr 26, 2017 | Washing Machines
Wat is the SE or 5E stand for on the Samsung washer and dryer combo
The 5E code indicates a water drainage problem.
Check the pump filter for blockage and debris.
Check the drain hose and waste connection for kinks and blockage
After everything checks out, select the spin cycle to drain water
Nov 23, 2016 | Samsung Washing Machines
DW80F800. What does 5E error code indicate?
Hello. Straight out of the service manual for your dishwasher...the 5E error comes from the low level switch not being detected within 3 minutes during the drain cycle...possible causes...clogged drain line, broken wire on the drain pump, defective drain pump, bad ECS, bad main board--in that order. Absolutely make sure there isn't something jammed in the drain pump that could slow it down or jam the impeller. Also, those drain brakes can be a real problem with mold/mildew gumming up the inside--once mold grows in these things, you MUST replace it--I've tried the cleaning route--it just comes back. I hope this helps you.
drain pump--DD81-01527A
main control board--DD82-01139A
Oct 15, 2015 | Samsung Dishwashers
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
May 03, 2017 | Samsung Washing Machines
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
Ive got a samsung t1253 its shows error code 5e how do i fix it
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 24, 2010 | Samsung WF337AA Front Load Washer
There is a fault se coming up how can i fix it?
SE/5E usually means blocked pump or unable to drain water out in allotted time
Mar 20, 2010 | Samsung B1245 Front Load Washer
Fault code 5E
possible pump problem
try cleaning out the filter
Nov 01, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
